Motor swap question?
Can i use my d15 ecu on a d16 motor? I'm not real worried about vtec working, I just want the car to run. Also can I use a B series ecu on a d series motor?
just get the right ecu for your engine.
i don't think you can run a B-series ecu on a D-series, or at least i don't think it will run properly.
a non vtec ecu will work fine to get it to run. i actually had to use a dx ecu to get my car through inspection. and it will not throw a CEL atleast mine didnt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">a non vtec ecu will work fine to get it to run. i actually had to use a dx ecu to get my car through inspection. and it will not throw a CEL atleast mine didnt.</TD></TR></TABLE>
I'm almost 99.9% sure that if you have a VTEC engine and you run a non-vtec ecu you will throw a code.. maybe your cel is burnt out.
Metal_SOL
10
May 15, 2002 08:45 PM
