is it possible to pass smog in CA with GSR motor in LS teg?
Old Feb 28, 2005 | 11:54 AM
oh-k's Avatar
Default is it possible to pass smog in CA with GSR motor in LS teg?
i have a 95 integra RS wiith a B18c1, gsr. is it possible to pass smog in California with this set up? if so how can i?
Old Feb 28, 2005 | 12:22 PM
TunerN00b's Avatar
Default Re: is it possible to pass smog in CA with GSR motor in LS teg? (oh-k)
Of course, if the motor is from the same or a newer year, just take it to a ref. You'll have to have all the proper smog equipment on it.
Old Feb 28, 2005 | 12:29 PM
purplegsr's Avatar
Default Re: is it possible to pass smog in CA with GSR motor in LS teg? (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">Of course, if the motor is from the same or a newer year, just take it to a ref. You'll have to have all the proper smog equipment on it.</TD></TR></TABLE>
Basically, you will need to take it the state ref, they are usually at community colleges and other governmental buildings. Make an appointment, make sure the vacuum/emissions diagram from the year for the GSR motor matches up to your setup exactly. It should be fairly easy, it's a little harder for JDM motors. If you have a 96-01 B18C1, you are going to have to switch to OBD2 (not sure if you already did), and if you have a 94 B18C you won't be able to get it certified by the ref, although you would probably pass smog if the motor is running well and the tech isn't a stickler for details.
Here is a site on it:
http://hybrid2.honda-perf.org/ref99.html
and do a search in archived content for username "Spade" he has done quite a few threads with very useful information.
B16b-EJ8
May 10, 2006 11:58 AM
oh-k
Aug 7, 2004 10:19 AM
wizzards581
Jun 14, 2003 11:08 PM
00fbp
Nov 28, 2002 09:29 PM
comptechgsr
Apr 11, 2002 11:32 PM
