Brakes, best bang for the cheep buck?
I need new rotors I think. Im pretty sure they are warped beond having them turned on a brake layth(sp?). What are the best rotors I can get for really cheep, and where? I just need somthing to get me by for about a year until I buy the FAST BRAKE big brake kit. Also, what pad and brake fluid would be good?
Okay, did you not see where I said I need a cheep brake setup to get me by until I buy the fast brakes? Im sure the setup you mentioned is not cheep!
u could go with powerslot slotted rotors or the brembo rotors and i would definately get some ss brake lines as well... (and if u have the cash the 3rd thing would be brake pads)
90-91 EX front brakes, nothing cheaper! Rotors gonna cost $120, why not just get the bigger brakes for another $30 and be able to build from there?
New Rotors? Call Steve Colletti and get some Brembo OEM rotors. Probably cost you around $100 for all 4 rotors.
http://www.collettimotorsports.com/
If you can deal with some squeel then get carbotech panther plus's in the front and change you fluid. There is no need to change rotors unless yours are warped. All of that cross drilled, slotted nonsense is not going to make you stop any better except in the most extream track situations. If your current rotors are bad then get the brembo OE's from coletti for about $100 for all four.
If you want to learn about brakes, and what to do to have better performance from them--then goto the competition forum. Most of the guys there are road racers and I'm sure they can point you in the right direction. HTH
If you are looking for an inexpensive upgrade, get some good quality OEM or equiv rotors and install some Hawk HPS or HP+ pads. These will give all the stopping you will need on the street or AX.
Devin
Devin
spoonhatchblack
Suspension & Brakes
Feb 13, 2008 03:19 PM
