Removing PS, What to do with VSS
Old Feb 28, 2005 | 11:00 AM
skrewdlude's Avatar
Default Removing PS, What to do with VSS
Hey guys,
On my last lude I had just ripped off all the PS stuff, and this was a mess. PS fluid would drip out occationally. This time I am doing it right with the breather set up. I am still unsure what to do with the VSS though. I looked through old posts, and everyone seems to not mention this. So did you guys just remove the lines from the VSS? The VSS is included in the PS system to control how much the PS does at various speeds, I thought, in this case it is no big deal to not give it any lines. I was just wondering if anyone knew if the VSS required oiling via the PS lines?
Thanks!
Old Feb 28, 2005 | 11:07 AM
prelittlelude's Avatar
Default Re: Removing PS, What to do with VSS (skrewdlude)
you loop the line on the vss.
Old Feb 28, 2005 | 11:13 AM
bdb's Avatar
bdb
Default Re: Removing PS, What to do with VSS (prelittlelude)
I didn't do anything with the VSS sensor... I would suspect that with all of the pump out and stuff even with the VSS sensor on and working it has nothing to control.
Old Feb 28, 2005 | 02:14 PM
skrewdlude's Avatar
Default Re: Removing PS, What to do with VSS (bdb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdb &raquo;</TD></TR><TR><TD CLASS="quote">I didn't do anything with the VSS sensor... I would suspect that with all of the pump out and stuff even with the VSS sensor on and working it has nothing to control.</TD></TR></TABLE>
This is what I was thinking, not its only job is the electric signal to the speedo.
Old Feb 28, 2005 | 02:38 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">you loop the line on the vss. </TD></TR></TABLE>
Old Mar 6, 2005 | 09:03 AM
H22ASH1's Avatar
removed ps from my h22 and everything was fine, its in an accord and the only default was my speedo was off because i need the original accord vss, **** outa luck
Old Mar 6, 2005 | 11:28 AM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdb &raquo;</TD></TR><TR><TD CLASS="quote">I didn't do anything with the VSS sensor... I would suspect that with all of the pump out and stuff even with the VSS sensor on and working it has nothing to control.</TD></TR></TABLE>'
you have a fifth gen, PS lines don't go to the VSS.
Anyways, just loop the lines, if PS is gone, there's no purpose, just loop them to close the holes and keep fluid in the VSS
Old Mar 6, 2005 | 12:08 PM
PirateMcFred's Avatar
I actually took mine apart and pulled out the gear pump, packed it with some grease and sealed the PS lines. But suppose that for a 4th gen you could just loop the PS lnes
Pirate
Urthwrite
Mar 11, 2011 08:08 AM
blaze.1
Sep 10, 2009 06:24 AM
dylokjai
Dec 2, 2006 06:15 PM
iTzKeviN
Aug 12, 2005 01:10 PM
degooser
13
Aug 18, 2003 10:57 PM
