Brake lights stay on after car is off...
Old Feb 28, 2005 | 10:09 AM
X2BOARD's Avatar
Default Brake lights stay on after car is off...
I've been told by a friend that had a similar problem that there is a little switch on the pedal that is causing the problem.
Well, I'll assume it's the same problem (both are EG models), but what is done to fix it (haven't looked yet) ? Will I need to replace the plastic switch thing or is there a way to adjust it ?
Old Feb 28, 2005 | 11:50 AM
X2BOARD's Avatar
faster than the speeding civic board !
Old Feb 28, 2005 | 11:57 AM
AutoXer's Avatar
Default Re: (X2BOARD)
So your brake lights are on all the time? Never go off?
If so, it's likely the switch.
Old Feb 28, 2005 | 12:01 PM
X2BOARD's Avatar
yep... never off... they're on right now... I can't take every tom dick and harry saying, "your lights are on"....
Old Feb 28, 2005 | 12:02 PM
X2BOARD's Avatar
So can anyone tell me if the switch needs replaceing or can it be adjusted ?
Old Feb 28, 2005 | 12:31 PM
Calvinator's Avatar
check if its getting stuck down
Old Feb 28, 2005 | 12:43 PM
AutoXer's Avatar
Default Re: (xtremeazian)
Yeah, you need to get in there and check it out to see if it needs replacing.
Old Feb 28, 2005 | 03:10 PM
93civicsedan's Avatar
Default Re: (EX_AutoXer)
try checking your bulbs one of them could be causing a short somewhere. i had a similar problem a while ago.
Old Feb 28, 2005 | 06:06 PM
EG1.8cT68's Avatar
It is your brake light switch. Look up under your dash where you brake pedal assembly is. Push on the pedal at the top of the assm. you will see a little rubber piece when you let off the pedal that rubber stop will hit you brake light sensor, you need to disconnect that sensor harness and remove the 14mm nut that holds it and replace that. When reinstalling it have a friend check you brake lights so you can adjust the sensitivity of the switch.
Old Mar 1, 2005 | 02:52 AM
X2BOARD's Avatar
Turns out the little rubber stopper deteriorated and fell off... I had to improvise and replaced it with a short bolt w/ a nut on the outer and inner end to adjust it's length.
Thanks all...
Old Mar 1, 2005 | 04:49 AM
bloopie's Avatar
Yep, thats what I did in my EF... did it with the brakes first, then the clutch switch died, just jammed a bolt in the holes for each pedal and wahlah... problem solved.
Old Mar 1, 2005 | 11:23 AM
EG1.8cT68's Avatar
Okay that will be $78 for diagnostic time I take paypal!
Old Mar 1, 2005 | 11:36 AM
X2BOARD's Avatar
Default Re: (EG1.8cT68)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG1.8cT68 &raquo;</TD></TR><TR><TD CLASS="quote">Okay that will be $78 for diagnostic time I take paypal!</TD></TR></TABLE>
Damn!!! You work for the dealer ?
I figured it out and fixed it yesterday afternoon... the good ole fashioned way... took off the tie, unbuttoned the top button and stuck my head under the dash.... holy gobs of grease batman ! I need a new clutch master cylinder !
EGKevin209
Jun 22, 2010 12:41 PM
Smash03
Lighting
Apr 28, 2010 12:10 PM
julio_bOostamante
Dec 7, 2006 05:04 PM
88crxhfb16
11
Jul 28, 2005 08:07 PM
virusx
Apr 28, 2005 12:13 PM
