Civic Burning oil!
Old Feb 28, 2005 | 07:56 AM
VTECdTypS's Avatar
Default Civic Burning oil!
I bought a 91 ef with 180k miles on it a couple months ago and its burning oil. About a quart every couple hundred miles, depending on how i drive it. would putting 10w-30 instead of 5w help since its heavier?
Old Feb 28, 2005 | 08:06 AM
b16sellout's Avatar
Default Re: Civic Burning oil! (VTECdTypS)
Get a can of restore, or Valvoline makes a high-mileage oil additive that will help too. Sounds you need new piston rings though.
Old Feb 28, 2005 | 08:09 AM
CRX Toad's Avatar
I'd run the 10W-30 in our older car no matter what. Notice any oil on the rear bumper? It could be front or rear main seal. If you can't see where it is coming from I'd guess it is a seal. Also check oil pan gasket.
Old Feb 28, 2005 | 08:16 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Civic Burning oil! (CRX Toad)
10w-40 will slow the burning... Try the maxlife stuff.
Old Feb 28, 2005 | 08:36 AM
nucivowner's Avatar
mine burns oil as well, and there isn't much you can do without rebuilding the engine. you can put some "no smoke" treatment in there but it will only last so long. are you sure its burning it? does it smoke out the tailpipe?
Old Feb 28, 2005 | 09:10 AM
c1v1c89h4tch's Avatar
Default Re: Civic Burning oil! (nucivowner)
there is this one stuff called smoke bee gone at autozone and checker works really good when my sohc was burning alot of oil i would use it and wouldn't burn as much, it really thick like honey
Old Feb 28, 2005 | 09:54 AM
H22HondaCRX's Avatar
get a new motor or rebuild the old one good luck
Old Feb 28, 2005 | 05:56 PM
VTECdTypS's Avatar
Default Re: Civic Burning oil! (c1v1c89h4tch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1v1c89h4tch &raquo;</TD></TR><TR><TD CLASS="quote">there is this one stuff called smoke bee gone at autozone and checker works really good when my sohc was burning alot of oil i would use it and wouldn't burn as much, it really thick like honey</TD></TR></TABLE>
yea, most of the time there is smoke coming out of it, even when its warm. it not just smoke cuz its cold.
Old Feb 28, 2005 | 06:12 PM
Super Chicken's Avatar
Seafoam! Run some (not all) through the intake as per the instructions then turn the car off and remove the spark plugs and pour about an ounce in each cylinder, allow the car to cool off then start it up and watch the SMOKE!!! After you drive it for awhile it will calm down and may possibly solve some of your oil consumption too. Buy aniother bottle and put 3/4 in your fuel tank and the rest in your crankcase. These 2 steps should free up your rings and help until you can rebuild it.
Oh, and make sure after the car cools off in the first step that you turn the engine over a few times (using the electric starter, not your hand) with the spark plugs out before you try and start it otherwise you will hydrolock the engine and bend a rod.
r.etheridge
21
Feb 11, 2011 07:33 PM
CroSi
Aug 14, 2003 04:32 PM
wm5holla
May 19, 2003 07:30 PM
Pinpid
Dec 17, 2002 04:55 PM
