window install?
Old Feb 28, 2005 | 07:29 AM
deconstruct's Avatar
Default window install?
how do i install a driver side window on del sol? is it complicated or is it pretty simple to do. the reason im wondering is because its cold outside and im trying to decide if i should just pay for the installation.
Old Feb 28, 2005 | 11:21 AM
Default Re: window install? (deconstruct)
anyone
Old Feb 28, 2005 | 11:35 AM
miahmouse's Avatar
Simple... remove inner door panel. remove two 8/10mm bolts holding window to rail. futs around with the vertical guide rails, loosening the bolts at the bottom to get the window out. repeat in reverse, lube everything up and you're done...
Old Feb 28, 2005 | 11:45 AM
Ls_V_TurboSi's Avatar
Default Re: window install? (miahmouse)
Basically what he said but slide the window in from the outside of the car not the inside and just make sure both sides of the window are in the rails
Old Feb 28, 2005 | 12:36 PM
miahmouse's Avatar
Default Re: window install? (Ls_V_TurboSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_V_TurboSi &raquo;</TD></TR><TR><TD CLASS="quote">Basically what he said but slide the window in from the outside of the car not the inside and just make sure both sides of the window are in the rails</TD></TR></TABLE>
this too I've also found it helps to get it in the tracks by aligning the back edge first then the front.
The whole process may take a few minutes but it'll save you probably $50-100....
Old Mar 1, 2005 | 05:41 PM
thanks for the advice. much appreciated.
alinton2005
Sep 12, 2018 08:09 AM
KaJeR
Aug 5, 2010 05:27 PM
conan4
Nov 9, 2008 04:47 PM
HatefulDjiN
May 23, 2006 03:14 PM
photec2
Jan 27, 2004 07:33 AM
