need help with wiring up a resistor box
Old Feb 28, 2005 | 02:58 AM
TYPErCRX's Avatar
Default need help with wiring up a resistor box
i have a fuel resistor box that i have to add to my DX CRX now on the box it has one red wire for power and the 4 black wires does it matter which red/black wires go on the resistor box????
Old Feb 28, 2005 | 03:27 AM
crxnj's Avatar
Default Re: need help with wiring up a resistor box (TYPErCRX)
Found this in the search..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">
you should have an injector resistor box with a gray connector on the side - you need the other side of this connector that goes to the engine harness with the wires cut - should be one yellow/black and four red/black - take the two yellow/black wires that went to the two DX injectors and connect them together and then connect them to the yellow/black on the connector to the injector resistor box - take the four red/black wires from the connector to the injector resistor box and connect one to each injector - doesn't matter what order - if you have injector resistor box without the engine side connector, you need to get this connector from a salvage yard - i see lots of resistor boxes on ebay without the other side of the connector with the wires on it - they are just about worthless, unless you want to hard wire it in with no way to disconnect in the future
markgo
Nov 8, 2006 11:39 AM
Dunc
Oct 2, 2005 02:12 PM
integramic
May 24, 2005 10:27 AM
DOHClessEF-9
Feb 5, 2005 04:35 PM
shivern
Nov 28, 2004 08:51 PM
