Honda S2000 Honda S2000
A question for S2000 owners.
Old Feb 28, 2005 | 02:13 AM
NewRacer's Avatar
Default A question for S2000 owners.
If you accidently press the engine button during the car in motion, will it shut down the engine?
Old Feb 28, 2005 | 03:09 AM
BOOSTEDS2K's Avatar
Default Re: A question for S2000 owners. (NewRacer)
with the clutch out it will not do nothing
Old Feb 28, 2005 | 05:27 AM
Francesco's Avatar
never tried it, always wanted to know what would happen
Old Feb 28, 2005 | 05:37 AM
NewRacer's Avatar
Default Re: A question for S2000 owners. (BOOSTEDS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTEDS2K &raquo;</TD></TR><TR><TD CLASS="quote">with the clutch out it will not do nothing</TD></TR></TABLE>
So, if I accidently press the engine button when the car is in motion, it won't shut the engine off?
How do you turn the engine off? Do you have to be in complete stop?
Old Feb 28, 2005 | 05:42 AM
Mr. Bagel's Avatar
I think you mean the start button.
- no it doesn't shut the engine off. it will try to start the running motor again, causing the starter to make clicking noises.
- to shut off the car, you turn off the key, just like any other car.
Old Feb 28, 2005 | 06:28 AM
Nishant's Avatar
Default Re: A question for S2000 owners. (Mr. Bagel)
^ what he said...don't push it in while on the clutch
Old Mar 2, 2005 | 09:51 AM
hypnosisracing's Avatar
Default Re: A question for S2000 owners. (Nishant)
Why?
Old Mar 2, 2005 | 10:40 AM
revhi's Avatar
Ive pushed it twice by accident before, it just trys to restart the car. Same as if you had a key and tried to turn it again after its on.
Old Mar 2, 2005 | 01:15 PM
Nishant's Avatar
Default Re: A question for S2000 owners. (hypnosisracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnosisracing &raquo;</TD></TR><TR><TD CLASS="quote">Why?</TD></TR></TABLE>
same as in a car without the start button and you move the key clockwise to crank, the start button will crank and does nothing, makes a very harsh sound though
Old Mar 2, 2005 | 09:31 PM
glass3ater's Avatar
I don't understand how or why it would shut the engine down... what is your thought process on that one?
Old Mar 2, 2005 | 10:36 PM
Razor's Avatar
Default Re: A question for S2000 owners. (glass3ater)
is this guy for real?
Old Mar 2, 2005 | 10:48 PM
glass3ater's Avatar
Default Re: A question for S2000 owners. (Razor)
well, he is a new racer... so I guess I'll try and go easy on him
Old Mar 3, 2005 | 05:26 AM
Nishant's Avatar
i guess he assumed you turn it off the same way you turn it on, ionno
Old Mar 3, 2005 | 06:49 AM
hahaha... i guess i should have made my post a little clearer...i wasnt asking why it did that, i was asking why he was asking this question. hahahah
Old Mar 3, 2005 | 06:58 AM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnosisracing &raquo;</TD></TR><TR><TD CLASS="quote">hahaha... i guess i should have made my post a little clearer...i wasnt asking why it did that, i was asking why he was asking this question. hahahah
he = noob, thats why
Old Mar 3, 2005 | 01:59 PM
roadhead's Avatar
Whats cruising RPM at 75 MPH in high gear guys?
Old Mar 3, 2005 | 02:36 PM
Francesco's Avatar
Default Re: (roadhead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadhead &raquo;</TD></TR><TR><TD CLASS="quote">Whats cruising RPM at 75 MPH in high gear guys?</TD></TR></TABLE>
what gear am i in at 75 and i'll answer that question?
Old Mar 3, 2005 | 05:58 PM
Nishant's Avatar
Default Re: (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">
what gear am i in at 75 and i'll answer that question?</TD></TR></TABLE>
high gear is prob 6th
Old Mar 4, 2005 | 06:21 AM
Francesco's Avatar
Default Re: (Nishant)
in 5h gear at 75 i am at 5xxx rpm...i looked this morning on the way home from school.
Old Mar 4, 2005 | 06:23 AM
Nishant's Avatar
what about 6th? i know i am at 5100rpm's at 80mph but i have 4.77 gears
Old Mar 15, 2005 | 08:56 AM
gomarlins3's Avatar
Is that a double negative?
Old Mar 15, 2005 | 09:27 AM
Francesco's Avatar
Default Re: A question for S2000 owners. (gomarlins3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gomarlins3 &raquo;</TD></TR><TR><TD CLASS="quote">Is that a double negative?</TD></TR></TABLE>
yes i think so...
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">what about 6th? i know i am at 5100rpm's at 80mph but i have 4.77 gears</TD></TR></TABLE>
i'll check tommorrow on my home from work when i can get on the high way...
Old Mar 16, 2005 | 06:24 PM
Francesco's Avatar
80mph in 6th im @ 4500 rpm...
Old Mar 16, 2005 | 07:10 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">80mph in 6th im @ 4500 rpm...</TD></TR></TABLE>
i'm only 600 rpm's higher, thats not much
