GSR Swap with wicked bad gas mileage...whats wrong? IDEAS?
Old Feb 28, 2005 | 12:46 AM
SLoWBoY636's Avatar
Default GSR Swap with wicked bad gas mileage...whats wrong? IDEAS?
Whats up everyone? My name is Dustin and I'm new to Honda-Tech. I have a 92 hatch with a 97 GSR swap. Motor pulls wicked strong for a stock GSR motor. Problem is the cars gas mileage is wicked bad. I probably get 7-9 miles a gallon. I tested the cars fuel pressure at work and read 50-55psi which is way higher than stock psi and the fuel pressure regulator is stock. The car runs extremely rich and idles like a 500hp beast. If you have any ideas please just let me know. Problem is really starting to get old and I am wasting so much money in gas. AGAIN motor is stock with just an exhaust.
Old Feb 28, 2005 | 05:04 AM
Jmunk's Avatar
Default Re: GSR Swap with wicked bad gas mileage...whats wrong? IDEAS? (SLoWBoY636)
Is the fuel return pinched ?
Old Feb 28, 2005 | 08:19 PM
SLoWBoY636's Avatar
Default Re: GSR Swap with wicked bad gas mileage...whats wrong? IDEAS? (Jmunk)
well my idea is that maybe the fuel return line is either pinched or clogged. i took off the fuel return line off the fpr and the fuel pressure dropped to 42-45psi which is closed to stock. so what i am gonna do is disconnect the other end of the fuel return line near the gas tank and turn the car on and run the line into a catch can and see if it comes out with pressure or barely streaming so that should give me an idea if its the hard line or not.
Old Mar 2, 2005 | 10:50 PM
SLoWBoY636's Avatar
bump
killerpenguin21
Jun 8, 2010 01:23 PM
damn_import_culture
Aug 27, 2009 04:56 PM
MassScene
Feb 2, 2005 08:55 AM
B18B1DOHC
Dec 23, 2003 10:48 AM
