sway bar and left wheel shakes
First off anyone know where to get decent prices on a rear swaybar for a 92 prelude? Also will it hurt anything to only switch the rear? and is there a difference between a swaybar and an anti swaybar?
The wheel shake... When i brake from like 50 mph it feels like my left front wheel shakes. It doesnt shake when im driving on the freeway or road, just when braking. what could cause this? I just replaced the axles and cv joints less then 1000 miles ago, but could it still be the axles causing this? (car also pulls to the right)
also when i turn my wheel far to the right i hear a kinda quiet popping noise, not too loud and doesnt seem to cause a problem other then be annoying.
alright, first off , sway bars and anti sway bars are the same thing, you can just replace the rear if you like, but I like matching sets, just depends on what you are doing and or budget. second, the shaking is from warped rotors, and the popping could be from ball joints, or axles. as for the pulling right, think about investing in a 4 wheel alignment, it will save tires in the long run
stevenbr549
Nov 23, 2014 11:16 PM
