help me....how do i make a circle in the metal flange?
Old Feb 27, 2005 | 10:19 PM
1.8's Avatar
1.8
Default help me....how do i make a circle in the metal flange?
noob question for u guys. easy for u guys but hard for me.....
i need to make a circle in the flange from my cat. it's the whitish/yelowish part. what tools can i use? dremel? i have a dremel but dont know which accessories to use. sears.com has pics of the accessories. if any of u guys can link me to the tool, that'll be very helpful. thanks....
Old Feb 27, 2005 | 10:25 PM
Goullish's Avatar
Default Re: help me....how do i make a circle in the metal flange? (1.8)
Try a drill bit. Go slow. Use coolant.
Old Feb 27, 2005 | 10:28 PM
1.8's Avatar
1.8
Default Re: help me....how do i make a circle in the metal flange? (Goullish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goullish &raquo;</TD></TR><TR><TD CLASS="quote">Try a drill bit. Go slow. Use coolant.</TD></TR></TABLE>
i'll try that. any other suggestions?
Old Feb 27, 2005 | 10:55 PM
Goullish's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">
i'll try that. any other suggestions? </TD></TR></TABLE>
Less accurate.
http://www.sears.com/sr/javasr...71000
It will take longer, and require more patience, but it will fit in your dremel.
Old Feb 28, 2005 | 04:33 PM
1.8's Avatar
1.8
cool. i'm gonna try the drill bit first. but why use coolant? can i use lube?
Old Feb 28, 2005 | 06:23 PM
SJcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">cool. i'm gonna try the drill bit first. but why use coolant? can i use lube? </TD></TR></TABLE>
He doesnt mean radiator coolant, he means machining lube. Im not sure what exactly you're doing... are you drilling through the cat material, or making a flange?
Rich
Old Feb 28, 2005 | 07:36 PM
1.8's Avatar
1.8
Default Re: help me....how do i make a circle in the metal flange? (SJcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SJcivic &raquo;</TD></TR><TR><TD CLASS="quote">He doesnt mean radiator coolant, he means machining lube. Im not sure what exactly you're doing... are you drilling through the cat material, or making a flange?
Rich</TD></TR></TABLE>
lol. told u i was a noob. i thought he meant radiator coolant.
i'm trying to drill through the flange. not making the flange.
Old Feb 28, 2005 | 07:38 PM
sporkcrx's Avatar
Are you just widening those holes for bolts?
Old Feb 28, 2005 | 07:50 PM
1.8's Avatar
1.8
Default Re: help me....how do i make a circle in the metal flange? (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">Are you just widening those holes for bolts?</TD></TR></TABLE>
yes. so i can install the spring studs/bolts.
Old Mar 4, 2005 | 03:38 PM
bjfisher's Avatar
wd40 will work, youjust need some kind of lube/coolant.that bit will heat up fast
vtec_lude
Welding / Fabrication
16
Sep 13, 2007 10:28 PM
@irborne
17
Nov 6, 2005 04:32 PM
sebZZ
Jun 4, 2005 09:18 PM
TrueUntilDeath.com
Group Threads
25
Mar 3, 2005 09:56 PM
GreenBean
Apr 13, 2003 01:43 PM
