Which factory honda or acuras seats will fit in a 1991 civic hatch?
Old Feb 27, 2005 | 09:49 PM
CivicRaping's Avatar
Default Which factory honda or acuras seats will fit in a 1991 civic hatch?
I was wondering what factory honda or acura front or rear seats would fit in my 1991 civic? does anyone know for sure?
Old Feb 27, 2005 | 10:22 PM
jdmcivicturbo's Avatar
Default Re: Which factory honda or acuras seats will fit in a 1991 civic hatch? (CivicRaping)
i really don't know if all the bolts will fits....but i've seen anything from gsr leather to simple ls integras fit the ef9......of course it might take some modification but just only a little.....if im not wrong the ls integras from 90-93 also the gsr same year bolt on directly.....the back too....so if u can get a pair maybe black leather......it would look really nice...
Old Feb 27, 2005 | 10:57 PM
eda6's Avatar
Default Re: Which factory honda or acuras seats will fit in a 1991 civic hatch? (jdmcivicturbo)
90-91 hatch seats will bolt in. Anything else requires modification (seat pan swap or welding your rails to another seat).
Old Mar 3, 2005 | 10:14 AM
GreenBean's Avatar
Default Re: Which factory honda or acuras seats will fit in a 1991 civic hatch? (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">90-91 hatch seats will bolt in. Anything else requires modification (seat pan swap or welding your rails to another seat).</TD></TR></TABLE>
So if I get a 94 and up gsr cloth seats I can swap pans with my 91-DX hatxh seats now.
Old Mar 3, 2005 | 10:16 AM
PHOBIA's Avatar
i have 94" gsr cloth seats in my car and its not a direct fit, you can do the 2 methods listed above or drill and tap new holes.
Old Mar 3, 2005 | 11:10 AM
crxtreme89h's Avatar
Default Re: (PHOBIA)
You can fit any seats you want. It will require modification to either the seats or your car. Good luck. BTW, this question is answered 2 or 3 times a week by me and a select few others.
You cannot swap the seat pans from your 94 GSR to your 90-91 Civic.
Old Mar 3, 2005 | 11:48 AM
cvcrcer's Avatar
Default Re: (crxtreme89h)
What about an 89 CRX? Can I just grad a seat out of an Integra or Hatch?
Old Mar 3, 2005 | 01:28 PM
menappi's Avatar
i got 99 gsr seats in mine. i didtn even drill or swap rails =P
Old Mar 3, 2005 | 03:50 PM
GreenBean's Avatar
Default Re: (menappi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menappi &raquo;</TD></TR><TR><TD CLASS="quote">i got 99 gsr seats in mine. i didtn even drill or swap rails =P</TD></TR></TABLE>
EXPLAIN THY SELF
Old Mar 3, 2005 | 04:03 PM
SoldMyEM1's Avatar
Default Re: (GreenBean)
I call BS. Unless of course you just sat the seats in there hoping that the weight of you sitting in it will hold it in place
Old Mar 3, 2005 | 05:24 PM
doublethink's Avatar
Default Re: (IheartMyEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IheartMyEM1 &raquo;</TD></TR><TR><TD CLASS="quote">I call BS. Unless of course you just sat the seats in there hoping that the weight of you sitting in it will hold it in place</TD></TR></TABLE>
prolly got one of the 4 bolts to line up and called it a day.
ghetto style.
Old Mar 3, 2005 | 05:35 PM
pwrofdrm's Avatar
Default Re: (doublethink)
I have 92 GS-R seats in my CRX...Had to do a seat pan swap, but it was worth it
Old Mar 4, 2005 | 05:57 AM
GreenBean's Avatar
Default Re: (lax1185)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lax1185 &raquo;</TD></TR><TR><TD CLASS="quote">I have 92 GS-R seats in my CRX...Had to do a seat pan swap, but it was worth it </TD></TR></TABLE>
So it was a straight forward pan swap right, no welding or fabricating?
And your recline feature works correctly.
Old Mar 4, 2005 | 06:09 AM
pwrofdrm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenBean &raquo;</TD></TR><TR><TD CLASS="quote">
And your recline feature works correctly.</TD></TR></TABLE>
Yeap, just took the pans apart, switched them over, I used zip ties instead of futzing around with those stupid little rings again. Everything works on the seats, bulster adjustment, lumbar support, recline...mmmmm
Old Mar 4, 2005 | 02:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lax1185 &raquo;</TD></TR><TR><TD CLASS="quote">I used zip ties instead of futzing around with those stupid little rings again. </TD></TR></TABLE>
Damn you! That was my idea! Maybe you read somewhere in the last 6 years?
Old Mar 4, 2005 | 07:37 PM
menappi's Avatar
lol i only have 3 of the 4 bolts in =P but the seats are secure and work fine. i had to play with it though to get the bolts in, but they are in. i also had gsr seats in my crx and i just used a piece of 3" flat iron and made a mounting bracket type thing to bolt the seats to and then i bolted that to the holes and the seats were in fully.
si_23
Apr 19, 2011 06:16 PM
+honda_monkey+
Jul 6, 2009 01:50 AM
Ilovemyef9
Mar 19, 2007 02:59 PM
Civic89stdB16
Feb 13, 2007 06:10 AM
allsho
Feb 4, 2007 09:29 PM
