spun a bearing
Old Feb 27, 2005 | 08:55 PM
deez nuts's Avatar
Default spun a bearing
is it fixable? how much would it cost to fix? also what type should i use if you can replace them?
bty its an type r mtr
Old Feb 27, 2005 | 09:02 PM
SOHC4life 96's Avatar
Default Re: spun a bearing (deez nuts)
Yes it is fixable, not easy, but fixable. You basically have to tear the whole bottom of the engine apart. Put some OEM or good aftermarket (research will tell you the best ones) in. But if you have sufficent oil, you won't have to worry about that happening again. Where are you located in CA, if you are in SoCal I might know someone that could do it for you for cheap. (cheaper than any shop around)
Old Feb 27, 2005 | 09:14 PM
eK9aT10pSi's Avatar
were you running low on oil for a while ?
Old Feb 27, 2005 | 09:46 PM
Tony Starks's Avatar
Default Re: spun a bearing (eK9aT10pSi)
Fixed two GSR's this week due to spun bearings. Time consuming, but not hard. Cheap? Maybe. If your crank is fucked it will need to be recut and add in a complete set of bearings too.
Old Feb 28, 2005 | 08:20 AM
deez nuts's Avatar
Default Re: spun a bearing (Tony Starks)
yes im from socal...... how much is cheap? im interested
Old Feb 28, 2005 | 08:21 AM
deez nuts's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi &raquo;</TD></TR><TR><TD CLASS="quote">were you running low on oil for a while ?</TD></TR></TABLE>
yes i was....
Old Feb 28, 2005 | 11:08 AM
deez nuts's Avatar
Old Feb 28, 2005 | 07:03 PM
deez nuts's Avatar
Old Mar 1, 2005 | 12:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deez nuts &raquo;</TD></TR><TR><TD CLASS="quote">yes im from socal...... how much is cheap? im interested</TD></TR></TABLE>
OEM crank from Acura is over $1000.
Having a machine shop cut your crank is roughly $150.
OEM bearings are around $12 per half.
Crank kits from various auto parts stores run anywhere from $300-$450.
Old Mar 1, 2005 | 05:30 PM
deez nuts's Avatar
sounds like it cost an arm and leg....... better off getting a new block?
i-VTEC_do_you
Jul 19, 2006 09:44 PM
gsr_b20x2
Oct 4, 2005 08:05 AM
precisionelite
Aug 22, 2005 10:37 AM
pyromaster
Mar 2, 2005 12:04 PM
dustin
Oct 23, 2002 12:06 PM
