a/c in eg with ls swap.
Old Feb 27, 2005 | 08:26 PM
rogue420's Avatar
Default a/c in eg with ls swap.
what parts will i need to get the a/c working in my eg with ls swap? do i need different a/c lines for the b-series compressor or will the ones from my eg work? what other stuff needs to be done. keep in mind that my eg came with factory a/c so all that stuffs in the car already.
Old Feb 27, 2005 | 08:32 PM
GSR-Civic's Avatar
the ones from your eg should work
Old Feb 27, 2005 | 10:06 PM
jeef84's Avatar
Default Re: a/c in eg with ls swap. (rogue420)
No, the lines will not work. Believe me I looked. Basically, you can either get a line made for you by a shop, or you can look into trying to find a del sol vtec a/c bracket, because the del sol's have the same frame. The low line from the civic will not twist to fit around the high line going into the compressor.
Old Feb 27, 2005 | 10:46 PM
eg6sir-s's Avatar
you can retain your stock ac compressor and lines with your ls swap in your eg. all you need to obtain is a P54 ac bracket which came from the 95 del sol vtec models.
just do a search for P54 ac bracket.
Old Feb 27, 2005 | 10:48 PM
eg4usdm's Avatar
or just not have a/c. that solves it
Old Feb 28, 2005 | 04:04 AM
dwnthehatch's Avatar
Default Re: a/c in eg with ls swap. (eg4usdm)
You can also use the "P7J" ac bracket from a crv which is half the price of the "P54" bracket.
Old Feb 28, 2005 | 05:44 AM
rogue420's Avatar
i knew someone was gonna say that.
Old Feb 28, 2005 | 05:46 AM
rogue420's Avatar
Default Re: a/c in eg with ls swap. (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">You can also use the "P7J" ac bracket from a crv which is half the price of the "P54" bracket.</TD></TR></TABLE>
can anyone comfirm this?
Old Feb 28, 2005 | 05:48 AM
rogue420's Avatar
Default Re: a/c in eg with ls swap. (eg6sir-s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s &raquo;</TD></TR><TR><TD CLASS="quote">you can retain your stock ac compressor and lines with your ls swap in your eg. all you need to obtain is a P54 ac bracket which came from the 95 del sol vtec models.
just do a search for P54 ac bracket.</TD></TR></TABLE>
so your saying that i use the a/c comperssor off my d-series and get a p54 bracket and be cool?
can someone else verify please?
Old Feb 28, 2005 | 06:22 AM
2lua's Avatar
i'm with him and had done on quite a few rides myself.
Old Feb 28, 2005 | 07:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rogue420 &raquo;</TD></TR><TR><TD CLASS="quote">
can anyone comfirm this?</TD></TR></TABLE>
38930-P7J-000 CRV Bracket
myself, ICU, boomslang, and ef ect all use the P7J bracket.
Old Feb 28, 2005 | 07:22 AM
rogue420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">38930-P7J-000 CRV Bracket
myself, ICU, boomslang, and ef ect all use the P7J bracket.</TD></TR></TABLE>
so you guys use the original eg a/c compressor, stock a/c lines, and this p7j bracket?
Old Feb 28, 2005 | 09:09 AM
so you guys use the original eg a/c compressor, stock a/c lines, and this p7j bracket?</TD></TR></TABLE>
Yes
InTheLBC20
Apr 18, 2009 09:42 AM
HondaBurger
May 25, 2008 09:46 PM
pucancakes
Jun 8, 2006 01:17 PM
PinkMaggit
Jan 9, 2006 06:58 PM
