Getting A/C back! couple questions..
OK well i thought taking out my a/c would make my engine bay look cleaner, but now its starting to get hot and im kicking myself in the ***. I put an LS in and i know you need a crv or del sol dohc vtec ac bracket to use the stock eg compressor, but i cant find any answers on putting an integra compressor on there. Do eg a/c lines work with an integra compressor? What all can i do besides getting that bracket, because its expensive and im broke.
Re: Getting A/C back! couple questions..
^^^ +1, i just pulled a ls motor from an integra today for my eg, and was wondering if i should pull the a/c lines with it. i got some of them.
matching generations a/c lines match up between b and d compressors and lines.
95 ex right? should be r134a, the teg compressor should hop right in
well i put the integra compressor on yesterday and the lines that run from the condensor and compressor dont line up the right way. You would have to bend one 90 degrees and the olther like 180 degrees to get it to bolt up correctly. So i bolted the eg one up with only two bolts! Hey, it holds it in place and if it works who gives a ****, right? Im off to the junkyard to grab some brackets and stuff the bolt the condensor in correctly. After that i need to hook up the rest of the lines and charge it. Let yall know what happens
kylefakesi-r
07-08-2007 10:10 PM
BanUglyImportModel
07-03-2003 07:42 AM
