those of you with full-race a/c manifolds, mounting ac condensor
Old Feb 27, 2005 | 08:19 PM
leadtrum's Avatar
Default those of you with full-race a/c manifolds, mounting ac condensor
mounting this thing with a pusher fan results in the wastegate coming about less than an inch away from the condensor.
how are you guys mounting these with the pusher fans and still not having to hack away a ton of your hood support area.
if you have pics that would be great cause the shop i'm taking it to is wary about cutting the support as am i.
Old Apr 30, 2005 | 11:11 PM
ssr_h22's Avatar
up. i have the ac manifold . its not on yet but i want info also
Old May 1, 2005 | 05:45 AM
leadtrum's Avatar
Default Re: (ssr_h22)
did people have to cut their hood support a lot to get this to work?
Old May 1, 2005 | 06:26 PM
BodyKits NW's Avatar
Default Re: (leadtrum)
I made a custom bracket to hold the condensor on top and also utilized the stock fan mounting brackets to mount the lower part. I was able to mount a pusher fan on it without a problem. I got the fan from B18bturbo.
Old May 2, 2005 | 05:54 AM
leadtrum's Avatar
Default Re: (BodyKits NW)
thank god, a valid answer. thanks
forryk
Jan 3, 2012 08:06 AM
oxSLEEPERxo
Jul 10, 2005 07:22 AM
Gfunk176
Apr 16, 2004 06:37 AM
NeXtLeVeL_TyPe_R
Jan 20, 2004 08:51 PM
