high idle
Old Feb 27, 2005 | 07:57 PM
yellowdcn's Avatar
Default high idle
when i turn on my car and its in park, my idle is on 1.5 rpm. Is that normal? and when its in d4 w/ a full stop, its at 1.0 rpm. is that normal ?
Old Feb 27, 2005 | 08:26 PM
hotaccord243's Avatar
Default Re: high idle (yellowdcn)
i would like to know this too, because thats how mine idles for a lil bit when started up, and then slows to 690-710 in idle after warmed up, but to me, thats normal
Old Feb 27, 2005 | 09:30 PM
goowakjai
Guest
Posts: n/a
Default Re: high idle (hotaccord243)
i have the same problem...idles at like 15-2G on start ups..then moves bak to 500-700 after warmed up...=/...i got a 95 accord LX btw
Old Feb 27, 2005 | 10:22 PM
LITTLEgiantoo17's Avatar
i believe that at cold start up, those are normal.
after the car warm up, idle is 750 rpm for accord...
well, this for my car...correct me if i'm wrong
also check the spec on your hood...it should tell you the normal idle at warm up
Old Feb 27, 2005 | 11:22 PM
_VTi_'s Avatar
Yeah seems taht this is a normal thing. Idling at 1500 to warm up then dropping between 600-800. it'll drop to this if you put it in drive (auto) too. otherwise it'll sit at 1500, designed to warm it up faster i believe.
Old Feb 28, 2005 | 12:05 PM
Nick H's Avatar
New User
Default Re: high idle (_VTi_)
the high idle is merely a way to warm the motor up faster...an idle of 1500-2000 will warm the motor up faster than the regular 750 rpm idle...this is what that little device on the intake manifold called the iacv is for...
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
kitt
Apr 29, 2010 11:57 AM
court76wi
Jul 2, 2009 02:50 PM
efyou
Apr 18, 2007 06:00 PM
