tape on o2 sensor wiring
Old Feb 27, 2005 | 07:46 PM
chihuahuamanx's Avatar
Default tape on o2 sensor wiring
i had to re solder my o2 sensors wires, and theyre soldered about 3 inches from where the sensor screws into the pipe. will this just fall apart? Im worried about the solder and the tape melting/disintigrating. damn i dont wanna buy another
Old Feb 27, 2005 | 07:51 PM
Nisif's Avatar
Default Re: tape on o2 sensor wiring (chihuahuamanx)
If you soldered the wires I think you should be alright, not exactly sure what temp solder melts, but I guess you'll find out if it does hold up...but it's worth a shot
Old Feb 27, 2005 | 08:17 PM
haha it sayyyssss..... 80degrees Celcius on it.............. thats 174F..... think thats good?
Old Feb 28, 2005 | 06:13 AM
ttt
Old Feb 28, 2005 | 08:06 AM
PrettyLude's Avatar
why didn't you heatshrink it?
Old Feb 28, 2005 | 10:53 AM
Default Re: (PrettyLude)
i uhh... dunno how. Any tips/ threads i should read?
Old Feb 28, 2005 | 11:00 AM
PrettyLude's Avatar
heat shrink is that tubing that goes around the jumper conversion harness at the ends, looks clean too
Old Feb 28, 2005 | 04:45 PM
i can get it at kragen or something? do i need a heatgun or something?
Old Feb 28, 2005 | 05:11 PM
i can get it at kragen or something? do i need a heatgun or anything?
Old Feb 28, 2005 | 05:34 PM
eda6's Avatar
Default Re: (chihuahuamanx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chihuahuamanx &raquo;</TD></TR><TR><TD CLASS="quote">i can get it at kragen or something? do i need a heatgun or anything?</TD></TR></TABLE>
yea you can get it at kragen. A heat gun is the best way to shrink the tubing.
Old Feb 28, 2005 | 05:43 PM
PrettyLude's Avatar
i use a lighter to shrink the tubing
Old Feb 28, 2005 | 05:46 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">i use a lighter to shrink the tubing</TD></TR></TABLE>
heat gun works much better. I bet your lighter can't shrink tubing on 10 wires at a time
Old Feb 28, 2005 | 05:56 PM
Default Re: (eda6)
ohhhhh **** he said you lighter ain't big enough for him!
Kegan
16
Nov 14, 2013 07:26 PM
cticknor666
Apr 3, 2011 10:41 AM
depriv9
Sep 26, 2007 11:28 AM
01blackgsr
Jun 24, 2006 06:23 PM
Bewkrazed
May 7, 2003 12:38 AM
