Help, i bog off the line
Old Feb 27, 2005 | 06:50 PM
95singlecamvtec's Avatar
Default Help, i bog off the line
I have justed installed a fidanza flywheel on my d16z6, it pulls hard in the higher r's but when i launch i bog alot before my rpm rises. The car was acting fine before i insatalled it, has anyone else had this problem before? Do i need to launch higher or is there another problem ( I'm already lauching at 4200)?
I already have an aem intake, DC 4-2-1 headers, magnaflow exhaust, MSD 6AL, MSD blaster3 coil, accel 8.33mm wires, Skunk2 intake maifold, no cat, JUN ecu, tokico 5 way adj suspension, neuspeed front tower brace, ACT stager 2 clutch. and my racing tires are nitto 555r's.
Modified by 95singlecamvtec at 8:02 PM 2/27/2005
Old Feb 27, 2005 | 06:59 PM
jerbear!'s Avatar
i dump the clutch @ redline for my d15 with azenis tires. so maybe you should launch higher and use less clutch
Old Feb 27, 2005 | 07:01 PM
Scotty Dosent Know's Avatar
Default Re: Help, i bog off the line (95singlecamvtec)
Lt flywheels arnt meant for dragracing, think more along the lines of autocross. If your cars specific purpose is drag I would put the stock flywheel back on otherwise you are going to have to launch at a higher RPM. I noticed this same thing when I put a lt flywheel in my RX7 but I dont drag race it so it didnt bother me. good luck
Old Feb 27, 2005 | 07:04 PM
Default Re: Help, i bog off the line (ECKO1980)
I thought about putting the stock one back in but wasn't sure. I wanted to wait and ask everyone here to see if any one else has had the same problem.
Old Feb 27, 2005 | 07:05 PM
Jerbear, have you broke anything lauching that high, my redline right now is 9900.
Old Feb 27, 2005 | 07:09 PM
Sleek98's Avatar
wouldnt want to lunch at 9900 rpms. cuz you wont make it to second gear. i would launch around 5000 and see if its better, just go to an empty parting lot and try at different rpms.
Chris
Old Feb 27, 2005 | 08:11 PM
JDMlyfestyle's Avatar
Just takes practice. try lightly feathering the clutch. dumping the clutch when your new at something can break something.
Old Feb 27, 2005 | 08:15 PM
RedHB..D15B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95singlecamvtec &raquo;</TD></TR><TR><TD CLASS="quote">Jerbear, have you broke anything lauching that high, my redline right now is 9900.</TD></TR></TABLE> Your redline is 9900? Considering you have a internally stock d16z6. take that bs to clubsi
Old Mar 1, 2005 | 03:44 PM
jerbear!'s Avatar
i dont have enough power to break anything. all i know is that it hooks up whenever i do that. but in your case maybe a higher launch is necessary or more practice with feathering the clutch. also, ur redline being 9900. just because you got some jun ecu doesnt mean your car can handle it.
Old Mar 1, 2005 | 03:49 PM
turbo*s2k's Avatar
Default Re: Help, i bog off the line (jerbear!)
launch higher
Old Mar 1, 2005 | 03:53 PM
RangerDan's Avatar
Practice.
Youve just tossed in a lightweight flywheel its gonna act different. 4000 rpm is way to low imo.
Listen to what these guys are saying, feather the clutch...any jerky clutch movements will cause either to much or to little grip. Once you feel the car has hooked up let it out all the way.
For instance in my b18c-r set up I launched (street tires) at 6800 rpm a slight feathering action and in the first 15 feet I was already in vtec.
Oh yeah....Practice.
Have Fun!
Old Mar 2, 2005 | 10:34 AM
Default Re: Help, i bog off the line (RangerDan)
Thanks for all the help every one i going to go out and practice. Also i know a stock sohc vale train won't handle going to 9900 rpm that why my MSD rev limiter is set at 7000 and my shift ligt is set for 6600. I might be able to go that high but there is no way i would.
Old Mar 2, 2005 | 12:40 PM
B18C2_sedan's Avatar
practice with feathering the clutch, practice with feathering the clutch, practice with feathering the clutch. That what I did.
Chobits16
Dec 30, 2011 08:31 AM
Xtream_V
Nov 10, 2006 05:45 PM
Lauj87
Sep 17, 2005 06:32 PM
G2Integrity
Aug 29, 2002 02:46 AM
