WIRING JDM GSR CLUSTER TO EG
Old Feb 27, 2005 | 06:35 PM
ch4nq's Avatar
Default WIRING JDM GSR CLUSTER TO EG
i've serched and found alot of wiring diagrams to this, but not any that was similar to mines. i have a jdm gsr cluster. looking at it from the back, top left has 14pins w/ 2 available slots, top right has 10pins, and bottom right has 10pins w/ 3 available slots. i could show you a pic but only if i can find my digi cam. i need some help on this. thanks in advance.
Old Feb 27, 2005 | 06:54 PM
BlueIntegraBoy's Avatar
Default Re: WIRING JDM GSR CLUSTER TO EG (ch4nq)
https://honda-tech.com/zerothread?id=1053318
You are supposed to use the 16 and 13 pin. You'll be using the 94-97 Integra cluster into 92-95 Civic diagram.
The middle slot is if your car is automatic. There would be another plug from the harness (gear lights) that plug into that slot.
Modified by BlueIntegraBoy at 6:25 PM 2/27/2005
Old Feb 27, 2005 | 06:58 PM
ch4nq's Avatar
damn thanks alot man...weew i thought i just wasted some money..thanks again
Chrisfrom1986
Mar 25, 2009 02:07 PM
ch4nq
Oct 7, 2004 05:44 PM
daxxbomb
10
Dec 31, 2002 06:15 AM
