wtf...passenger-side window malfunction?
Just today my passenger side window will not roll up/down from either the driver or passenger side switch.
Any ideas on what the problem is?
If anyone has any ideas for a possible fix, please try and be detailed with the how-to, im a bit of a.....newbie
anyways, any help appreciated, thanks guys
something weird happened to me. Afriend rolled down the window, and it wouldn't roll back up. it chilled there for about 30 sec, and then I tried it again and it was slow as all heck, but it went back up. ever since it has worked "ok"
I know this won't really help, but I figured it was still on topic
not to be insulting to your intelligence but have you made sure that the window lock is not enabled. if it is the window won't roll up from either console. just a thought
Hi, I'm a newbie on here and I've had the same problem on mine. The fault on mine is with the connections to the drivers door control switches. Make sure the connections are good and it should be fine.
As a quick test, press quite hard on the plastic panel that surrounds the drivers control for the passenger window and at the same time work the switch, you might find it'll work.
Cheers
Buzzinvtec (UK Luder) JDM 2.2 VTEC 4th gen
Cheers
well, i popped off the plastic panel and took a look at the connections to the switches, sure enough, it had gotten loose somehow.
Thanks for the tip Buzz, that was a really embarassing/annoying thing with the car
PS- Burn: If I had the window lock really enabled and posted here i would slap myself in the face for you guys, lol.
EGcivicBoy
Dec 15, 2003 09:52 PM
