b16 ECU's
Old Feb 27, 2005 | 05:03 PM
athoughts's Avatar
Default b16 ECU's
b16a2
I have a jdm p30 unchiped currently ..
im ordering the hondata s200
what am i gonna have to do here to get this setup?
i know alot of things are going to have to be done..
any information would help
thanks
Old Feb 27, 2005 | 05:07 PM
StreetEG's Avatar
Default Re: b16 ECU's (athoughts)
I have a chipped p28 but some bullshit mugen program...apparently it sucks. Hondatas definately the way to go
If your located on the east coast...Jeff Evans (boosted Hybrid) has neptune.... apparently with more features. As soon as i get enough money ill def be hittin that up.
AS for compatibility i think your good with the p30 just get dyno time and do it right
Old Feb 27, 2005 | 05:15 PM
athoughts's Avatar
Default Re: b16 ECU's (StreetEG)
yeah tuning and stuff is not a problem, i have places to get that done
i need info on how to install it in my car ,
im not to formiliar with the socketing and ****
and with having the jdm p30 , i didnt know about complications and if i have to use the p28 or not
Old Feb 27, 2005 | 07:56 PM
athoughts's Avatar
i have a b16a2 with obd2 to obd1 conversion, and the obd1 to the jdm p30
im getting the hondata s200 with a p28, will those plugs and everything line up or am i going to have to do some more conversions?
Old Feb 27, 2005 | 11:17 PM
athoughts's Avatar
bump
Old Feb 28, 2005 | 12:25 PM
athoughts's Avatar
Old Feb 28, 2005 | 12:27 PM
dantastic's Avatar
http://www.hondata.com
Old Feb 28, 2005 | 12:40 PM
athoughts's Avatar
Default Re: (dantastic)
doesnt answer my question
Old Feb 28, 2005 | 12:52 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16a2 with obd2 to obd1 conversion, and the obd1 to the jdm p30
im getting the hondata s200 with a p28, will those plugs and everything line up or am i going to have to do some more conversions?</TD></TR></TABLE>
what car is it going into?
http://www.hondata.com/vehicles.html
"Many vehicles require an OBDII to OBDI adapter harness (note 6) and/or ECU swap (note 7)."
and if you went to the hondata website and poked around, you'd find out that all obd1 ecus have the same pinout.
Old Feb 28, 2005 | 12:56 PM
ajzeg's Avatar
Default Re: b16 ECU's (dantastic)
you can get a harness thats converts it for you obd1 will not work with obd2 if thats you question, ithink it is called a jumper harness
Old Feb 28, 2005 | 01:12 PM
athoughts's Avatar
Default Re: b16 ECU's (ajzeg)
what i need to know here is if the p28 will plug into where the p30 is, are they the same plugs?
killerbseries
Apr 27, 2005 10:47 PM
towns
11
Jun 3, 2004 10:46 AM
FerioVtec94
Sep 10, 2003 07:39 PM
crx1856
Jun 15, 2003 09:37 PM
