TRANNY CASE!! HELP
my tranny caseing has a big hole in it, i believe that there are two casings, the one closest to the tranny fluid bolt is messed up, are tranny casings interchangeable through b series trannys? i got a USDM type r transmission
no ALL of the casings ARE the same. Depending on the year of the hydro it will have different races for either a open face bearing, or a closed bearing. You can easily pop these races out and put the races in from your old tranny.
The housing though is exactly the same.
I had to change mine a few months ago when the bolts ripped out from the back mount.
