How can I test my obd1 check engine light
I was told if you have a obd1 if you turn the ignition 2 times the check engine light will blink a certain amount of times to show you the problem code is this true and is it really done like that
you have to connect the jumper on the pass. footwell. it is the 2 wire one in the green rubber sheath tucked under the dash closest to the door. us a paperclip.
1long=10
1short=1
IE 4 long 3 short =43...
more than one and there is a space. youll see what i mean
1long=10
1short=1
hey, i have a 91 crx si and my whole harness was messed around with. anyway, the only plug i found free was a blue/purple one with a green and brown wire. do i jump that one? dont mean to jack the post or anything
existanzcivicb20
20
May 22, 2017 04:23 PM
Jdmefsir12
Jul 1, 2012 08:13 PM
91highryda
Oct 6, 2007 08:24 AM
