clutch so soft why??
Old Feb 27, 2005 | 02:42 PM
vtec_crazy's Avatar
Default clutch so soft why??
hey people my clutch pedal is sSO AND I MEAN SO light. why is that? .got a new clutch installed and grabs good but high but its sooo light to push the pedal down.
can anyone explain.
and if i adjust the pedal to get the grab point lower my gear changeing feels weird)feeling the gears)
so many questions so little answer
Old Feb 27, 2005 | 03:51 PM
clemsoncb7's Avatar
Default Re: clutch so soft why?? (vtec_crazy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_crazy &raquo;</TD></TR><TR><TD CLASS="quote">hey people my clutch pedal is sSO AND I MEAN SO light. why is that? .got a new clutch installed and grabs good but high but its sooo light to push the pedal down.
can anyone explain.
Could be many things. Could be your slave cylinder, throwout bearing, whatever. Also, you could have a broken, unhooked linkage somewhere.
Old Mar 2, 2005 | 10:33 PM
Dai_Ca_Vietnam_H22a4's Avatar
I had the same problem. I changed out my clutch and presure plate one day. Then a few weeks later the clutch pedal was light as paper. I decided to replace the master and slave clutch cylinder and the problem went away. The clutch pedal was immediately tighter. I hope this helps.
shortlid
Sep 26, 2013 10:16 PM
Philip
Honda Fit
10
May 21, 2006 03:51 PM
onyx00
Aug 20, 2004 11:34 PM
qtiger
Oct 22, 2002 05:35 PM
