Will I pass inspections?
Old Feb 27, 2005 | 02:22 PM
chahsiubow's Avatar
Default Will I pass inspections?
My SRS light came on the other day and I'm not sure why. I know you're suppose to repack the airbag or change the chemicals that deploy it every 10 yrs (I have a 95), but I'm not sure if it's just a warning light or if it's FUBARed. I don't feel like jumping the wires to check the number, since given the luck I've had with this car, it'll prolly deploy on me. So, I was wondering if having the light on will cause me to fail NYS inspections. I'm assuming yes, but my roommate said he passed before with the light on, so I'm just double checking with you guys to see if you had the same experience.
Oh yeah, if I reset the light, will the info be saved and the tech will catch it when he plugs my car into the diagnostic check?
Old Feb 27, 2005 | 09:00 PM
GTWITIT's Avatar
Default Re: Will I pass inspections? (chahsiubow)
i dont know how NY is but in VA it fails. good luck
Old Feb 27, 2005 | 09:22 PM
Haleiwa-Brando's Avatar
Killing the power to your car for 5 minutes or more resets the ECU. I've never heard of a fluid that co-insides with the airbag. I think that may be jiberish. So before you go get inspected, pull into a parking lot and chill out for a bit with the battery disconnected. Drive over and get it inspected. Maybe it will work... *shrug
Aloha,
Brandon
Old Feb 27, 2005 | 09:28 PM
chahsiubow's Avatar
Nah, resetting the ECU still gives me the SRS light. I was referring to jumping the blue cable underneath the glove compartment.
Old Feb 27, 2005 | 09:35 PM
Bspec18's Avatar
Default Re: (chahsiubow)
Per OEM Manuals the SRS light can only be turned off by using a diagnostic computer. Just remember the SRS computer is seperate from the ECU, its located in the center console behind the ash tray
Old Feb 27, 2005 | 10:18 PM
Default Re: (Bspec18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bspec18 &raquo;</TD></TR><TR><TD CLASS="quote">Per OEM Manuals the SRS light can only be turned off by using a diagnostic computer. Just remember the SRS computer is seperate from the ECU, its located in the center console behind the ash tray</TD></TR></TABLE>
Well noted! Thought the ECU trick would do the job. *shrug. Ah well. Good luck with your inspection.
Aloha,
Brandon
Old Feb 28, 2005 | 02:55 AM
JDMGSR EG's Avatar
Default Re: (Haleiwa-Brando)
ca doesnt give a **** about that stuff
Old Feb 28, 2005 | 02:40 PM
chahsiubow's Avatar
anyone in NYS know for sure?
Old Feb 28, 2005 | 02:56 PM
Explorer22's Avatar
I'm pretty sure it will fail. Inspections are there for safety. If for some reason your airbag light is on, then they can't pass it - because if you get in a wreck and the bags don't deploy....the shop could be screwed, and well - you in a wreck without airbags, would leave you screwed as well.
-Drew
Old Mar 1, 2005 | 11:02 AM
vtecfed's Avatar
Default Re: (Explorer22)
pull the cluster and remove the bulb. pass inspection. put bulb back in and get abs fixed.
Old Mar 1, 2005 | 12:48 PM
chahsiubow's Avatar
i thought they plug cars into computers 95+... otherwise i would have tried that already.
Old Mar 1, 2005 | 12:51 PM
PLAGUED_DB7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMGSR EG &raquo;</TD></TR><TR><TD CLASS="quote">ca doesnt give a **** about that stuff</TD></TR></TABLE>
no, they care about stupid *** front plates and not SRS systems go figure
jeremypr
Feb 26, 2009 11:22 AM
d2r
Dec 5, 2008 05:27 AM
ls_4dr
Dec 23, 2005 01:27 AM
StolenTeg
Nov 28, 2004 08:19 AM
ShakesTheKlown
Mar 14, 2004 01:36 PM
