BC IV's or Toda C's
They will be going in a gsr with ctr pistons, eagle rods, i/h/e, mani and hondata. probs omni valvetrain and aem gears. I want 190 - 200whp daily driver without a crazy idle. what do you guys think?
No need for such aggressive cams if all you want is 200whp on that setup, also you will get a CR of 12.6 or so with the CTR pistons, maybe a little high for a daily driver? JDM ITR pistons is more than enough, with a GSR head your CR will be around 11.4, combine this with BC3 or 3+ or Toda A or even ITR cams and you should get what you want.
I got the same amount of whp on my stock ITR with I/H/E and some tuning on a VAFC2, so it's not to hard a goal to reach. This was with Mugen intake and Hytech header and exhaust btw, there's much power to be had from using high quality I/H/E parts over cheaper alternatives.
So I should reach 200 with bc3's with the ITR pistons? Only reason I ask I cause I dont want to get everything and make like 180 and than kick myself. I mean I'd rather shoot for 195-200 and make like 210 and spend more money than come up short.
I also plan to sleeve the crank to 85.5mm thanks to njin buildr's advice. Will that affect the compression and how big of affect will that have on the power aspect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryanEk »</TD></TR><TR><TD CLASS="quote">I also plan to sleeve the crank to 85.5mm thanks to njin buildr's advice. Will that affect the compression and how big of affect will that have on the power aspect.</TD></TR></TABLE>
i cant get over this statement, lol
and now you want 190-200, instead of mid-200's. and no more itr pistons huh...
dang. cool setup..oh AND
stop making so many threads
There go's my credibility in one post.
Glenn
Glenn
AllMotorDan
12
Aug 8, 2011 03:00 PM
Blazin Si
21
Jan 14, 2004 10:47 AM
