gsr vs b16__ which head is better for ls/vtec
Old Feb 27, 2005 | 09:45 AM
686_ef's Avatar
Default gsr vs b16__ which head is better for ls/vtec
a have a gsr head on my ls/vtec and alot of people argue that the gsr head is weak for this set up, that b16 is the way to go. i think that a gsr head has better flow than a b16. any info would be nice.
Old Feb 27, 2005 | 11:57 AM
siR cr-x's Avatar
Default Re: gsr vs b16__ which head is better for ls/vtec (686_ef)
you are right a gsr head is better, it does flow better than a b16 head, and if i'm right the combustion chambers are smaller on the gsr head too but i'm not 100% sure about that
Old Feb 27, 2005 | 12:15 PM
NJIN BUILDR's Avatar
The is a ton of info in the search.They are both close in real world performance.The b16 stock intake is good to work with so I usually suggest that head for the guy on a budget.If your getting an aftermarket intake it comes down to which one I run across first.They are both good heads.
Glenn
Old Feb 27, 2005 | 04:15 PM
dfoxengr's Avatar
Default Re: gsr vs b16__ which head is better for ls/vtec (NJIN BUILDR)
its all relative, neither is "better" IMO
Old Feb 27, 2005 | 08:24 PM
686_ef's Avatar
Default Re: gsr vs b16__ which head is better for ls/vtec (hybridvteceg)
i just wanted to know. if there both stock which will give you better performance. i also heard that the gsr cams are a little better than the b16 cams.. also which head would be better ported. thx foo the info. i love HT
Old Feb 28, 2005 | 12:46 AM
A.I.M Sponsored Driver's Avatar
Here it is: GSR head has 41.5cc combustion chambers where B16 head has 42.7cc. The GSR head will raise compression by like .2 appr.
Old Feb 28, 2005 | 06:45 PM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 686_ef &raquo;</TD></TR><TR><TD CLASS="quote">i just wanted to know. if there both stock which will give you better performance. i also heard that the gsr cams are a little better than the b16 cams.. also which head would be better ported. thx foo the info. i love HT </TD></TR></TABLE>
if ur gonna go ls/vtec atleast have type r cams IMO
Old Feb 28, 2005 | 09:17 PM
irev210's Avatar
Default Re: gsr vs b16__ which head is better for ls/vtec (A.I.M Sponsored Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A.I.M Sponsored Driver &raquo;</TD></TR><TR><TD CLASS="quote">Here it is: GSR head has 41.5cc combustion chambers where B16 head has 42.7cc. The GSR head will raise compression by like .2 appr.</TD></TR></TABLE>
thats not the only difference, but thats a main one
combustion chamber design, port angle, blah blah blah.
it is a totally different head, practically flows the same.
Pick your fancy, one isnt clear cut better than the other.
Both have advantages, both have disadvantages
Old Feb 28, 2005 | 09:24 PM
NightmareApex's Avatar
The gsr head raises the comp by 0.3 actually :-D I just put a b16 head on a gsr block, and I lost 0.3 comp, and most piston manufactures state 0.3 in there catalogs.
If you where to port both heads, there wouldnt be much difference, but stock for stock I like the b16 head better, Ive had less problems with high revs and valve train wear.
Old Mar 3, 2005 | 05:03 PM
686_ef's Avatar
Default Re: gsr vs b16__ which head is better for ls/vtec (NightmareApex)
thnx fo the info
dixie Normas7
Apr 28, 2006 08:28 AM
RaceCarRyne
50
Nov 29, 2005 01:35 PM
Spectrum24x
Feb 10, 2005 06:50 PM
Option
Nov 1, 2004 12:53 PM
thehammer
Dec 22, 2003 04:36 PM
