Fork on tranny loose help
Old Feb 27, 2005 | 09:31 AM
gtowni3's Avatar
Default Fork on tranny loose help
oh man this really sucks....
few days ago my clutch went all the way down at a light and i was trying to bleed it and i would get no compression, then i saw my slave cylinder was ripped open and all the fluid was coming out, so i changed it and then again the boot ON the slave started filling up with fluid looking like it was going to blow up, and then it wouldnt build any pressure again, keep going dead pedeal when i would think i was done bleeding....so my friend came over and noticed the slave was extended all the way and like 3 more inches than it was supposed to be and the fork was loose and far back, so he says the tranny needs to come off.........think its the pressure plate or throwout bearing?
Old Feb 27, 2005 | 10:30 AM
gtowni3's Avatar
Default Re: Fork on tranny loose help (gtowni3)
help?
Old Feb 27, 2005 | 10:32 AM
Kamin's Avatar
you dont know till you remove the transmission, does it really matter wich one it is? the trans has to come off eithre way.
Old Feb 27, 2005 | 10:45 AM
gtowni3's Avatar
Default Re: Fork on tranny loose help (Kamin)
exactly what i thought, damn
Old Mar 1, 2005 | 06:01 AM
gtowni3's Avatar
ok found out problem.....everything is fine it was just the fork that broke, i wonder if it broke from having such a strong clutch
Old Mar 1, 2005 | 07:16 AM
EE_Chris's Avatar
Damn - you broke the fork that pushes the throw-out bearing??
What kind of clutch are you using?
thierry
Feb 26, 2010 12:33 PM
EG2Driver
Oct 16, 2006 03:49 PM
01DC-2
Apr 17, 2004 12:36 PM
H22Chameleonaccord
Dec 30, 2002 10:59 AM
