machine shop cost... DONT LET ME GET SCREWED
Old Feb 27, 2005 | 08:48 AM
chihuahuamanx's Avatar
Default machine shop cost... DONT LET ME GET SCREWED
hey all, ill be to the point. i need:
(3) holes on my turbo have stripped threads, need them helicoil/timecerted
(1) downpipe flange on the downpipe needs milling/whatever to be straight again.
(1) weld around my 3" dp. \
What should i be willing to pay and not be getting screwed? not too much right? with the right tools, doesnt it seem they could do this pretty damn quickly?
Old Feb 27, 2005 | 09:20 AM
Engloid's Avatar
OG Fabricator
Default Re: machine shop cost... DONT LET ME GET SCREWED (chihuahuamanx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chihuahuamanx &raquo;</TD></TR><TR><TD CLASS="quote">hey all, ill be to the point. i need:
What should i be willing to pay and not be getting screwed? not too much right? with the right tools, doesnt it seem they could do this pretty damn quickly?</TD></TR></TABLE>
If your downpipe flange isn't welded on, why would it need resurfacing?
Anyway, check into having it done at a weld shop. You can likely drill the holes out and put bigger bolts in them, avoiding the need for a helicoil.
You likely don't really need the precision of having the flange resurfaced. A belt sander will get plenty flat enough for a good gasket to seal.
If it were me doing the work, I'd feel guilty charging anything over $100, and maybe less. however, a machine shop probably won't touch the stuff for that.
Old Feb 27, 2005 | 09:32 AM
Default Re: machine shop cost... DONT LET ME GET SCREWED (Engloid)
well the flange is pretty damn warped, thats what stripped the thread ont he turbo in the first place.
You think drilling them out will fix the holes? if the flange is nice n straight, i wont have to tq them down too hard to get a good seal right?
Old Feb 27, 2005 | 11:12 AM
Engloid's Avatar
OG Fabricator
You may be best off to cut the flange off the downpipe, bolt it to the turbine housing, then weld the pipe back on it while it's bolted up. Of course you want to do this without the gasket in place.
If you drill them out, you sill need to retap them to a larger bolt size. Just find the appropriate drill bit, tap, and replacement bolts before you drill it out.
Old Feb 27, 2005 | 11:49 AM
Bailhatch's Avatar
how hard is it to tap the cast steel housing? The only time I have fucked up a tap is chasing threads on a turbine housing so im thinking that actually tapping one would be a delicate process.
Old Feb 27, 2005 | 11:52 AM
Default Re: machine shop cost... DONT LET ME GET SCREWED (Bailhatch)
yea thats why i think im going to let the shop do it. I really dont wanna **** anything up, ive come WAY too far to mess up here. EVERYTHING else is on the car ready to go, this is just raping me for time
and again, everyone think that 100 for the whole process sounds good?
Old Feb 27, 2005 | 11:56 AM
Engloid's Avatar
OG Fabricator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it to tap the cast steel housing? The only time I have fucked up a tap is chasing threads on a turbine housing so im thinking that actually tapping one would be a delicate process.</TD></TR></TABLE>
It's not too hard. With the PROPER drill bit size, and lubricant, it's not anything hard to do at all, comared to tapping any other type of material.
Old Feb 27, 2005 | 12:10 PM
how long would it take an expirienced machinist dyou think?
Old Feb 27, 2005 | 05:49 PM
TTT
Old Feb 27, 2005 | 06:40 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid &raquo;</TD></TR><TR><TD CLASS="quote">
It's not too hard. With the PROPER drill bit size, and lubricant, it's not anything hard to do at all, comared to tapping any other type of material.</TD></TR></TABLE>
Huh, you'd think chasing threads would be easier. I drill and tap alu and mild steel all the time. I always use the right bit too, must have been retarted that day.
Old Feb 27, 2005 | 06:57 PM
Finland's Avatar
in my machine building days, I used to use reverse rotation drill bits to drill out broken bolts...usually by the time you got done drilling, the old bolt would come out and the threads were saved..it does take some skill and precision to do, but they shouldn't charge you too much.
Old Feb 27, 2005 | 07:45 PM
Engloid's Avatar
OG Fabricator
Huh, you'd think chasing threads would be easier. I drill and tap alu and mild steel all the time. I always use the right bit too, must have been retarted that day.</TD></TR></TABLE>
Why would you want to chase threads? If the threads in there are bad, you can only clean them up where a bolt goes in...you can't put metal back on the threads where it has been messed up. Therefore, even if using a helicoil, the proper fix is to drill and tap to a larger helicoil, then put it and the oversized bolt in.
Even if you do a half *** fix just by cleaning up the threads with a tap, you really can't put the strength back in there that it had before.
Old Feb 27, 2005 | 07:56 PM
Bailhatch's Avatar
Just cleaning them up, they were not stripped in my case, just happend to chip off a bit of the tap for some reason.
Old Feb 27, 2005 | 07:59 PM
Engloid's Avatar
OG Fabricator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">Just cleaning them up, they were not stripped in my case, just happend to chip off a bit of the tap for some reason.</TD></TR></TABLE>
Sure, if the threads are still good, I'd definitely not helicoil or retap it.
I've had great luck with bolt extractors. I have never broken one, and never failed in the task. Chasing the threads afterwards just to clean them out can't hurt.
Old Feb 27, 2005 | 08:57 PM
well mine are stripped like a ****. any more suggestions? imunna try and drop by a machine shop i found in the yellow pages tomarrow.
that-guy
Welding / Fabrication
Sep 14, 2011 09:30 AM
K i l l a B e e.
Sep 19, 2007 04:37 PM
jeffk182
Feb 21, 2006 07:32 PM
chihuahuamanx
Jan 28, 2005 07:17 PM
Tru Dynamix
Oct 4, 2002 08:58 PM
