H22 AN-R header fitment problems help!!!
I have a 91 jdm SiR h22a in a 98 Civic CX. I recently purchased and recieved an AN-R header. My problem is this header hits the alternator plug!! I have not driven the car yet, but in this setup I have no doubt it would damage or melt the alternator plug. Does anyone know of an altenator that puts out the same amperage that doesnt have a back mounted plug on the altenator and that will mount on my engine? I really dont want to relocate my alternator. Its more of a pain that its worth in my opinion, but if all else fails I will do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DTR-FAB »</TD></TR><TR><TD CLASS="quote">try making a custom alternator braket tomove it till it clears and fine the right belt...</TD></TR></TABLE>
problem is looks like no matter what bracket u put on the top, the plug is going to hit. If I had room I could get a longer belt and pull the alternator away some. Problem is I have (at the most) about 1" of clearance between the alternator pulley and the driverside headlamp assembly. There just isnt any room to come out to clear the plug!! I thought perhaps the USDM H22s, or some Accord engine might have the same amperage alternator with a different plug location which would help me out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junbb1 »</TD></TR><TR><TD CLASS="quote">change your belt length.</TD></TR></TABLE>
read my post above. I can't!!! too close to headlight assembly!!!!
i saw a while back a custom bracket that actually mounted the alternator where the AC compressor used to go. This way it clears the headlight, the header and everything else. I did a quick search but couldn't find it. It is out there though. Make a detailed look... BTW, did you contact AN-R?
worst case scenario is to get ahold of a 93+ h22 or h23 alternator and alternator plug which is smaller and just change it.
personally I'd just ditch the alternator plugs and run 4 spade connectors and fully insulate all of them.
greg
greg
djnikko
Dec 9, 2014 04:34 AM
_jester_
Dec 13, 2003 08:00 AM
