f22 tranny with h22 motor question
Old Feb 26, 2005 | 09:00 PM
18gLUDE's Avatar
Default f22 tranny with h22 motor question
i have a 91 accord and i just got a h22a4 off of my buddy. can i use the f22 tranny with the h22 motor? how will this affect the gearing? any info is appreciated.
Old Feb 26, 2005 | 10:12 PM
matix's Avatar
Default Re: f22 tranny with h22 motor question (18gLUDE)
Gears are way too long. Your gonna wish you waited for a h22 tranny.
Old Mar 1, 2005 | 07:11 AM
drift dreams's Avatar
wont the h22 also put down more of a beating on the tranny since its not designed to support that much hp.?
Old Mar 1, 2005 | 09:05 AM
matix's Avatar
Default Re: f22 tranny with h22 motor question (drift dreams)
There basically the same tranny with diffrent gear ratios.
Old Mar 1, 2005 | 11:54 AM
Stew Pidasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift dreams &raquo;</TD></TR><TR><TD CLASS="quote">wont the h22 also put down more of a beating on the tranny since its not designed to support that much hp.?</TD></TR></TABLE>
I really doubt Honda decided to build a tranny weaker because the engine puts out 50~ less horsepower
Old Mar 1, 2005 | 12:03 PM
Stoich EG2's Avatar
Default Re: f22 tranny with h22 motor question (Stew Pidasso)
if you plan on turbo'ing anytime in the future, i suggest you keep the F22 tranny. if you plan on using it with an NA H22, it's good on gas but your power band will smack you in the face for it's lack of use.
Old Mar 1, 2005 | 05:30 PM
BaddMo2002's Avatar
The F22 tranny runs good with the H22. The H22 tranny will obviously work better but the F22 does the job well.
Old Mar 2, 2005 | 03:45 AM
matix's Avatar
Default Re: (BaddMo2002)
THe h22 tranny is best for FI and N/A. There was a big thing on this a while back. People were claiming the longer gears of the f22 tranny is better for boost. Actaully you want shorter gears giving faster acceleration. But eighter are good for boost. I just wouldnt run a f22 tranny on a n/a h22. At least get a h23 tranny.
CD8coupeSiR
May 12, 2006 04:00 AM
BergRacing21
Jan 12, 2006 03:43 PM
Siegfried
May 16, 2004 02:17 AM
streetspeed607
Apr 12, 2004 12:54 PM
