Can someone tell what compression a 1.185 dome height yeilds.....
Old Feb 26, 2005 | 07:46 PM
powerfulperformance's Avatar
Default Can someone tell what compression a 1.185 dome height yeilds.....
This is in a 85mm gsr block with a b16 head......
Old Feb 26, 2005 | 08:28 PM
CHEETAH's Avatar
Default Re: Can someone tell what compression a 1.185 dome height yeilds..... (powerfulperformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerfulperformance &raquo;</TD></TR><TR><TD CLASS="quote">This is in a 85mm gsr block with a b16 head......</TD></TR></TABLE>
1.185 is prolly not the dome height, its the compression height, i.e. the location of the wristin pin from the deck of the piston, its is used to determine the length of the rod used give the stroke. 1.185 is the stock compression height of most b-series pistons.
Greg
Old Feb 26, 2005 | 09:50 PM
Default Re: Can someone tell what compression a 1.185 dome height yeilds..... (CHEETAH)
oh yeah i made a mistake. Thanks for the responds......
Old Feb 28, 2005 | 10:08 PM
rjay8604's Avatar
see if you can find out the dome volume. But the compression height can play a role too, when it is changed.
cashshoes
18
Dec 15, 2006 09:12 AM
0bd1_Kanobe
Mar 19, 2004 01:30 PM
YOSOLO CRX
13
Nov 13, 2003 08:53 PM
othick
Apr 2, 2003 04:32 PM
