Condenser Fan draining my battery
Old Feb 26, 2005 | 06:12 PM
sykotic's Avatar
Default Condenser Fan draining my battery
For some reason starting yesterday my condenser fan stays on after the car shuts off, it hasnt done this before yesterday... I have no clue what's causing it and I haven't installed anything or changed anything in a week or 2 on the car. I am at a loss here, the only things I have found is that the lights on the climate control stay on after the car is off as well, not the lights inside the pictures but the indicator lights that show which buttons are pushed in. I can pull the condenser fan fuse under the hood and both will shut off if that tells you anything. I don't know if maybe there is a relay or something but I know there is a cooling fan relay in the same fusebox but I dont really thing it would be the same relay for the condenser fan, would it? I have a turbo timer but it can't possible be the wiring for the timer causing it because I didn't hard wire it, I opted for the SVT pigtail harness and it just extends the ignition harness's with a pig tail for the turbo timer to plug in, and I tapped into the ground for the cigarette light harness wire.
If anyone has had this issue please help me out, or if you have any ideas for me to check, please shoot, i'm about ready to try anything...
Old Feb 26, 2005 | 11:31 PM
sykotic's Avatar
Default Re: Condenser Fan draining my battery (sykotic)
really need help guys =/
Old Feb 27, 2005 | 08:30 AM
sykotic's Avatar
AHHH!! BATTERY DEAD! HELP!
Old Feb 27, 2005 | 08:38 AM
DarkDragon's Avatar
bump since mine stays on too. stayed on last night for a good while and im pretty worried about it. I just installed a AEM CAI but i dont see how that could cause it
Old Feb 27, 2005 | 12:06 PM
sykotic's Avatar
Default Re: Condenser Fan draining my battery (DarkDragon)
argh, this is pissing me off, I can only find info on the 90-93 integra fans staying on, i've looked and looked and looked and I cant ******* find the relay for the condenser fan, the helms manual says its right there beside it in front of the compressor under the drivers headlight BUT I DONT ******* SEE IT! AAAHHH!!!!! HELP!
Old Feb 27, 2005 | 01:32 PM
sykotic's Avatar
ok I got it, it is the condenser fan relay, it is under the radiator support, between the radiator and the front bumper, it is actually mounted to the radiator support but the relays are under it, I had to remove my front bumper to get to them...
NAS95
Jan 15, 2018 01:51 AM
NVMYDC
Jul 20, 2011 08:06 AM
mark2583
Jan 20, 2010 10:46 AM
lilo_goki
Dec 3, 2007 02:47 PM
M-EJ1
Nov 17, 2002 06:57 PM
