need HELP, can't get fog lights to work!!
Well, after a 5 hr. install, everyhting is hooked up just as it should be, except the fog lights don't come on. The instructions say that the last step is to hook the remaining connector to a switch, but none ever came with my fog lights.. So this could be the problem. The other thing is that where the "knee bolster" goes, which I see no use for and am leaving off, I connected the relay and ground wire to where the left bolt goes to it, so I just don't know. Any gosu fog light installers plz help.
I don't know what "fuse" you're referring to, but yes everything is hooked up properly, other than that i'm thinking Handa-accessories forgot to include the switch with my kit.
thats exactly the same place i placed the relay and ground, cept with the knee bolster still on there... cuz the place it says on the instructions is already taken up by my alarm... i was skeptical about it, but it works and i dont run into any problems.
the on/off switch doesnt come with the install kit. that is a seperate piece which is discontinued. i found one on ebay luckily. without it, you cant turn it on/off
4serioferio
Aug 13, 2012 03:30 PM
EK_kidd
24
Oct 13, 2008 01:24 PM
sony224422
Mar 14, 2006 10:24 AM
