jack points on the R...
There are the 2 on each side and 1 in the front and 1 in the rear. If you look under th fron you will see the location - you really can't miss it. In the rear use the towing hook...
Yes, on the side ones, you have one right behind the front wheel and the other right in front of the rear wheel.
The good thing about the front side ones is that by using them you can lift the entire side of the car. Good for rotating or switching wheels quick
where do you usually lift from to change oil....
I have this cute little kragen 2.5 ton jack that doesn't lift it high enough to put jacks on the sides...
safe to lift from the engine mount?
maybe it's just time to get a real jack....=\
i always just use the front jack point for oil changes...it's true, you really can't miss it. also be sure to use jackstands whenever you're underneath the car!
TehMoonRulz
May 24, 2006 08:40 PM
