Will 96-00 civic struts fit 94+ integra?
if aftermarket yes. if stock ones, the front ones need to be grinded down on the top since it will not go into the hole so you can bolt it in to the car.
Not exactly, the 96-00 civic struts will bolt up perfectly in the front, and the rears will have a narrower fork than is necessary to fit over the Integra LCA - so you will need to shave a bit of the LCA bushing or swap in 96-00 civic LCAs (although you may have issues with your rear sway if using civic LCAs).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civiceg6 »</TD></TR><TR><TD CLASS="quote">just use the front wishbones from the ek and you should be fine </TD></TR></TABLE>
You don't need ek drop forks, the fronts will fit fine as is. It's the rear that gives you problems due to the fork (which is attached to the shock body) being too narrow.
vsi1600
May 23, 2010 10:55 PM
vlc92189
Jul 29, 2007 02:28 AM
Log4n
Dec 11, 2006 08:42 PM
jimmhatch
Mar 4, 2004 10:28 AM
