obd0 distributors
Gotta few questions regarding OBD0 dizzy's. I understand that they are composed of cap/rotor/ignitor/ICM ? What is a common cause of code 15? If the cap/rotor is worn will this cause a code 15? I have a code 15 and am wondering if I should just replace the cap/rotor OR entire dizzy. Thanks.
From: I told you to wait in the truck in Texas, United States
code 15 ignition output signal
usually the ignitor would be to blame..
if you have a d-15 or d-16 ignitor
laying around,give it a try..
rebuild instructions [watch-out for pop-ups]
http://www.angelfire.com/ca/Dr....html
Modified by 88DXCRX at 5:58 PM 2/26/2005
Good info. So the ignitor is available separately? I will take my distributor apart this weekend to inspect everything. Thanks.
Most auto part stores carry an aftermarket version..
I have compaired the stock ignitor numbers on a D-16 to that of a B-16
and they where the same..so I assume it would work..
[I carry it with me for a spare..]
An ariticle that might help:
http://www.markl.f9.co.uk/howt...r.htm
There are 2 oem ignitors, a black one and a brown one. The black one is thought to be inferior, but anything can wear out. Also tack jumping is classic symptom of a faulty ignitor. Check your Helms, there is an ignitor input test that can help diagnose your problem. Or.....jus buy a new dizzy and don't worry about it!
HTH
chris
HTH
chris
hans stoner
Oct 22, 2006 07:13 AM
