Custom Brake Lines
Old Feb 26, 2005 | 12:44 PM
nickzed20's Avatar
Default Custom Brake Lines
I need to run a brake line (existing is no good anymore), and i figured that i should just do it myself instead of paying for them at honda
i understand how it all works, and how to do it, but i just have a few technicalities to work out:
- Does honda use a 37degree or 45degree inverted flare?
- Where can i get the brake line nuts that are needed? I believe its 10 x 1.0
- Are our brake lines 3/16ths? cuz i did some practice flares and it seems that my tool is really hacking up the tube, as though its too small, maybe i just have a shitty tool?
Anyways, thanks a lot for anyone who has any input... anything else i should know about hondas brake lines, or making custom lines would be a big help!
PS: i did ALOT of searching already, and on the internet there isnt much info other then "how to flare"... which ive already read up on
NOTE: I am talking about HARDLINES here, not replacements for the rubber tubing that goes directly to the calipers... I am running lines between the master cylinder and proportioning valve
Old Feb 26, 2005 | 02:47 PM
AceRaceParts's Avatar
Default Re: Custom Brake Lines (nickzed20)
Shoot me a PM or give me a call. We are the supplier for John Force Racing and many other automotive companies in the brake and fuel line department.
Most people run 3/16" x .028 or 3/16" x .035 stainless tubing for their hardline brake lines. If you'd like I could recommend the best size od and wall thickness for your application. We also stock all of the necessary fittings.
Richard @ Ace Stainless Supply
800-888-8769
rich@acestainless.com
Old Feb 26, 2005 | 05:06 PM
DaveF's Avatar
Default Re: Custom Brake Lines (mbpwrx)
do you sell any high quality flaring tools?
Old Mar 2, 2005 | 08:20 AM
Default Re: Custom Brake Lines (Dturbocivic)
Sorry about the delay in posting...
Yes we do carry high quality flaring tools. We also carry tools for those on a budget.
Old Mar 5, 2005 | 03:57 PM
92HB_HB's Avatar
i'm in the process or re-running my metal lines from the fire wall to the back brakes of my 4dr teg as well
I recently noticed that my brake pedal was feeling spongy and going all the way to the floor.. I was also losing brake fluid from the resivior.. well low and behold my lines under the car had rusted through and the fluid was leaking there..
I just went to Autozone and bought 4 60" hard lines w/ the correct fittings at the end and two unions at Murray's.. total bill was : about $28 in parts
i'm gonna put in the new parts in the next day or so cuz i need my car to get around..
hopefully you'll be able to find the parts at ur local auto parts store... THey should have what u need..
Old Mar 5, 2005 | 09:33 PM
nickzed20's Avatar
Default Re: Custom Brake Lines (92HB_HB)
my main question is if honda uses a 37 degree or 45 degree flare
i did a 45 degree flare and everything seems to be great so far... i havent rode the car yet (its currently without an engine) but i threw in some fluid and primed the brakes, and i havent seen a leak yet
the real test will be when it throw on the suspension and brakes and hook it up properly, then do some actual braking
Old Mar 6, 2005 | 12:59 AM
Mullet_SyTy's Avatar
http://www.classictrucksweb.com/tech/0501cl_brake/
some helpful info here.
You are good with 45 deg for automotive brake systems, even Honda's.
37 deg is for AN fittings.
Old Apr 28, 2005 | 10:36 PM
manekDC2.'s Avatar
Default Re: Custom Brake Lines (Mullet_SyTy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mullet_SyTy &raquo;</TD></TR><TR><TD CLASS="quote">http://www.classictrucksweb.com/tech/0501cl_brake/
37 deg is for AN fittings.</TD></TR></TABLE>
awesome site!! great info there
regnevazota
Nov 24, 2014 04:55 PM
EF9_TryMe
Jun 20, 2011 06:25 PM
nickzed20
10
Feb 26, 2005 12:43 PM
