POST your 1/4 miles times with ls turbo
ok, i have $2300 to build my engine in my 96 integra rs but it MUST be able to run 12's or else i dont get the money, so i was just wondering if anybody has broken into the 12's with just a turbo kit on a b18b i really dont want to have to put rods and pistons in but if have to i will. So lets see some track times!!!
why won't you get the money if you don't run 12's?
if your simply buying a kit and not building the internals, you will not get into the 12's, you will be running around the low 14's or high 13's boosting at 7--psi.
you could run it. turbo+10psi+slicks+good driver on stock internals, you could prolly pull it off. if all else fails crank it to 14 psi for a run or two get yor money then buy a new motor
How much time are you going to have to practice launching? What if the car is ready on time and the diver is still warming up their skills?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcMONSTER »</TD></TR><TR><TD CLASS="quote">you could run it. turbo+10psi+slicks+good driver on stock internals, you could prolly pull it off. if all else fails crank it to 14 psi for a run or two get yor money then buy a new motor</TD></TR></TABLE>
Yup..a buddys EF with a B18b1 turbo (10psi) ran mid 13's high 12's, but he spun a bearing a few weeks after due to poor tuning/ drove it like an asshat.
make sure to run a compression test and learn how to launch pretty damn good and it can happen...also tune, tune, and dont forget to tune.
good luck
good luck
It can definitely be done... I don't know how many runs your gonna get before you cook the motor... maybe 10...possibly more as long as you got a nice setup
Crank up the boost and get ready to rebuild it.
Goodluck, would love to see your slip after you run
