GSR hydro tranny pops out of 5th only...
Old Feb 26, 2005 | 09:01 AM
Nytmair's Avatar
Default GSR hydro tranny pops out of 5th only...
So i finally registered my car last night, it's a 94 civic cx with b18b and GSR hydro tranny....
Everything seemed fine until it popped out of 5th gear by itself a few times...
Any reason it would do this, or anyway to fix this easily?? If not i'll just have to push the shifter forward since that works fine
Thanks for any help...
Old Feb 26, 2005 | 11:52 AM
playskool's Avatar
Default Re: GSR hydro tranny pops out of 5th only... (Nytmair)
check your tranny fluid
Old Feb 26, 2005 | 06:36 PM
Nytmair's Avatar
how would that effect it popping out of only 1 gear?
Old Feb 26, 2005 | 10:44 PM
omgwtfhaxnub's Avatar
Default Re: (Nytmair)
5th gear is furthest away from the tranny fluid or something along the lines of that. its more than likely low
Old Feb 27, 2005 | 11:10 AM
SpeedingHatch's Avatar
Default Re: (omgwtfhaxnub)
check ur fluid, n00b
Old Feb 27, 2005 | 02:15 PM
Nytmair's Avatar
thanks man, i'll check that out
Old Feb 27, 2005 | 06:08 PM
NVturbo's Avatar
O.G. triple O.G.
Plain and simple..your 5th gear synchros' are going bad!!!!! get it changed!!
Old Feb 27, 2005 | 11:48 PM
warrick's Avatar
Default Re: GSR hydro tranny pops out of 5th only... (NVturbo)
happened to a friend of mine with his Si transmission.
turns out his axles weren't the proper ones, leaked his MTF out, and he destroyed his differential.
Old Feb 28, 2005 | 06:41 AM
playskool's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nytmair &raquo;</TD></TR><TR><TD CLASS="quote">how would that effect it popping out of only 1 gear? </TD></TR></TABLE>
please just check your MTF.. ive seen this happen numerous times.. if it looks low you gotta figure out where its leaking from.. usually axle seals or a improperly installed axle.
and DONT hold the shifter forward youre doing more harm then good.
Old Feb 28, 2005 | 04:17 PM
Nytmair's Avatar
ok thanks for the info!!
JDM-EJ698
Sep 1, 2006 03:26 PM
J.nguyen
May 18, 2006 09:48 PM
teg969
Feb 25, 2006 08:54 AM
FLCivic
10
Apr 14, 2004 07:19 PM
SimbaDogg
Feb 22, 2004 10:11 AM
