D16z6 head with a temp d15XX swap leaking oil into radiator... HELP
Old Feb 26, 2005 | 08:02 AM
DemostheneZ's Avatar
Default D16z6 head with a temp d15XX swap leaking oil into radiator... HELP
I have never heard of oil getting INTO the radiator, it's always been the reverse, i've drained the oil, and there's no water in the block, does anybody have an idea what's going on?
Old Feb 26, 2005 | 09:50 AM
Default Re: D16z6 head with a temp d15XX swap leaking oil into radiator... HELP (DemostheneZ)
help plz, any ideas?
Old Feb 28, 2005 | 05:45 PM
hondaguyexsi's Avatar
when you have a bad or blown headgasket, oil gets into the coolant and coolant gets ito the oil. its not always necessarly both it could be on or the other
Old Feb 28, 2005 | 05:57 PM
smokee's Avatar
Default Re: D16z6 head with a temp d15XX swap leaking oil into radiator... HELP (hondaguyexsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyexsi &raquo;</TD></TR><TR><TD CLASS="quote">when you have a bad or blown headgasket, oil gets into the coolant and coolant gets ito the oil. its not always necessarly both it could be on or the other</TD></TR></TABLE>
yup a bad headgasket would be about the only way to get oil into your coolant and vice-versa. unless there is an oil cooler or something i dont know about, but im pretty sure there isnt on civics
Old Feb 28, 2005 | 06:36 PM
killer6993's Avatar
Default Re: D16z6 head with a temp d15XX swap leaking oil into radiator... HELP (smokee)
I've had the same problem before. HeadGasket! Nothing else I know of it could be.
keslerbuilt
Dec 29, 2013 12:24 AM
littleblue
Oct 12, 2008 06:16 PM
racingfan
May 2, 2006 11:19 AM
92jdmhatch
10
Dec 28, 2004 07:53 PM
92hybridAccord
Nov 26, 2003 04:05 AM
