what cam do I choose?
I'm gonna build a b20 vtec and don't know what cam to choose. Was thinking bc4 s2s3 or rocket motorsport m22 but really don't know which to choose so I would like some help thanks. Also would the shocks from a eg fit on a 90 si crx?
be specific..which vtec head you using?..what are you aiming for midrange?..top end?...do you want to rev the **** out of your motor?are you building your bottom end?aftermarket springs,retainers,valves?keep in mind bc4's skunk 3's m22's involve dipping past the 8000rpm mark to make full power..what are going to use for tuning?..view my sig I went with bc'3 stock b20 bottom end..dont want ot rev past 8200..block will be built for it next year..hope that helps ya out..good luck with your build
Fully ported and polished b16 head ferria valve train 12:5:1 cp pistons resleeved block micropolished crank ect.... Fully built but don't know what cam or header to go wit for this 2.0 setup.
kil2002
14
Oct 26, 2009 03:55 AM
mrtrex
26
May 29, 2006 08:44 PM
