missing bolt leading to oil leak?
actually there is no bolt that goes there. on my 96 civic, D16Y7 theres no bolt there, and unless you have the EX its the same motor. looks like dirt collected on oil though. I think your valve cover gasket is leaking. Get that gasket replaced, its a thin rubber lining thats not too expensive.
you can go to a goodyear place, or sears, pretty much any auto shop or place that does maintanence work can do it. Its 5 bolts to remove the valve cover, so its a simple thing to do. Any shop could verify what it is, but it really looks like that gasket leaking to me. if you want to do it yourself, go to a Honda dealer, get the part, and also get some "liquid gasket" which you simply apply to this rubber gasket (it helps make a nice watertight seal.)
there is actually no engine ground on the valve cover, its on the water pump. wierd i know. at least on my y7 that hole is just there.
P.S. hey Option...english only man, what the hell is all that junk?
looks like carbon build up. everyone gets that, but in your case that's more than normal...
i say go to a shop and have them replace ur valve cover gasket. dont forget to honda bond it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OptionMan »</TD></TR><TR><TD CLASS="quote">2005年2月25日夜
さあこれは本当に問題じゃないと思いますよ。一般的に言うとその汚れは多分オイルディプスティクからかバル ブカバーから出て来てしまったでしょう。
しかし今のようにそれぐらいで出てるのは安心です。もっともっと出たら困るですが今ほどには心配しない方が 大丈夫だと思う。
wtf?
wtf?
しかし今のようにそれぐらいで出てるのは安心です。もっともっと出たら困るですが今ほどには心配しない方が 大丈夫だと思う。</TD></TR></TABLE>
maybe i'm not quite understanding this. looks like oil with dirt buildup
i think that hole is there so you can screw in something so you can get the valve cover off easier. i would not recommend using that hole as a ground. i wouldnt worry about a leak, thats just normal build up.
You have no problem there. Same hole in my 97 Y8. Like others said it would not be a good ground point anyway. Best used for a mounting bracket to hold a cable etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">My 98 y8, that hole is used to ground from the radiator support to the valve cover.</TD></TR></TABLE>
What ? Why would you ground the radiator ?
My 97 Y8 has this hole and it looks like its tapped but there is no hole below it in the head. Since the valve cover has a gasket/rubber it does not make sense to ground anything here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic »</TD></TR><TR><TD CLASS="quote"> did u clean it up first and too see if it gets dirty agin?</TD></TR></TABLE>
yeah i cleaned it up, but i haven't checked if it's built up again. it was clean when i bought it and 3 months down the road, that's what showed up gradually..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alotawatts »</TD></TR><TR><TD CLASS="quote">
My 97 Y8 has this hole and it looks like its tapped but there is no hole below it in the head. Since the valve cover has a gasket/rubber it does not make sense to ground anything here.</TD></TR></TABLE>
Yeah I'm an idiot, I went out and checked later this afternoon and found it to be just an empty bolt hole.
piggydog
Feb 27, 2006 04:46 PM
eg crunkmonster
Feb 3, 2004 08:47 PM
