Hydraulic brake system problem.. is it? or not? help!
Old Jan 20, 2002 | 01:37 PM
acuraLSSE95's Avatar
New User
Default Hydraulic brake system problem.. is it? or not? help!
Recently I've been hearing low squeak noises when I brake, I could only hear it squeak when I'm driving with the music off. It doesn't make loud noise like buses do. Today, when I was driving and came to a stop light, I had my foot on the brake pedal. I felt that the pedal gradually went downward, and I had to step on it harder. As I stepped harder on it, I could feel that the car is moving forward a little bit but when I release my foot and step on it again the car stayed still. Then it starts again, after a little while holding the pedal down with my foot, the pedal gradual went down again. Brake fluid level is fine. I'm planning to bring it back to acura soon. My car is Auto, and driving and braking is fine on freeways, only happens when totally stopped at a stop sign or at a light with foot on pedal. What is wrong? Is it difficult to fix?
[Modified by acuraLSSE95, 10:39 PM 1/20/2002]
Old Jan 20, 2002 | 02:03 PM
T817's Avatar
Default Re: Hydraulic brake system problem.. is it? or not? help! (acuraLSSE95)
try bleeding your brakes
Old Jan 20, 2002 | 02:06 PM
New User
Default Re: Hydraulic brake system problem.. is it? or not? help! (A_red_car)
what do you mean by that? I'm pretty new to all this.
anyone else know what to do?
Old Jan 20, 2002 | 04:35 PM
rjardy's Avatar
YEAH YOU MIGHT HAVE AIR IN YOUR BRAKE LINES by bleeding them you get all air out of them and replaces it with fluid, the reason that the pedal went down is caiuse air can be compressed and fluid cant , thats why we use fluid. on each one of your calipers there is a bleed valve, have a freind in the car with presure on the brake, while he is holding presure, turn the bleed valve, keep it open till all the air comes out, do this at every corner , start with the one furthest away from the master cylinder, and dont forget to keep the master cylinder full of fluid!! hope this helped! oh yeah i allmost forgot .................DONT LET THE PRESUR OFF OF THE BRAKE UNTILL YOU HAVE CLOSED THE BLEED VALVE AGAIN!!
HAVE FUN MAN, IT CAN GET MESSY!!!!
Ardy
Old Jan 20, 2002 | 11:39 PM
Mista Bone's Avatar
D Tranny Guru
Bad master cylinder, replace ASAP. It's lack of holding pressure is source of sqwueaks
lovelove
Sep 20, 2009 04:40 AM
manyakiexpi
Apr 14, 2006 01:45 AM
FR-MOB: ThE bEe GuY
10
Jul 23, 2003 03:30 PM
acuraLSSE95
Jan 21, 2002 08:19 AM
