(Harness Help) sick of people not knowing what their talking about
Old Feb 25, 2005 | 08:30 PM
BoostJockey's Avatar
Default (Harness Help) sick of people not knowing what their talking about
Ive got a 99 b18c going into a 96 civic and dont know what harness to use. Peeps have told me to use the b18's harness, but its not right. And some say use the harness that came with the car, while others say Obd2a and Obd2b harness pin outs are too diff.
Im gonna use the 99 gsrs Ecu. Hook me up with some answers.
Old Feb 25, 2005 | 09:12 PM
Hockey27925's Avatar
Default Re: (Harness Help) sick of people not knowing what their talking about (BoostJockey)
your answer to this problem is use ur stock harness switch the iacv add the vtec wires and the knock sensor and get a jumper harness from obd2a to 0bd2b thats about, if u need anymore help just pm me there are plenty of articles on this in hondaswap.com
Old Feb 25, 2005 | 10:04 PM
v4lu3s's Avatar
RTFM
id persoanlly grab a 99 civic si or civic ex harness sicne it will match the ecu.
Old Feb 25, 2005 | 11:08 PM
thanks much
Old Feb 26, 2005 | 02:25 AM
importboi22's Avatar
use your stock harness with a conversion harness on the ecu side to run the 99 ECU you will have to add the wires for vtec, knock, IAB, switch some of the CYP sensors i think...... and if your car is a DX/LX/CX WHATEVER it maybe you will have to extend the MAP/TPS/IACV and some other wires .... 96-98 harnesses are a pain in the ***
Old Feb 26, 2005 | 07:33 AM
Default Re: (Harness Help) sick of people not knowing what their talking about (importboi22)
actually if he tries to use the 96 harness and plug in the 99 ecu, it will not work, the car will not even start
Old Feb 26, 2005 | 11:28 AM
Evil-EK's Avatar
Default Re: (Harness Help) sick of people not knowing what their talking about (Hockey27925)
You use a 96-98 ex harness. You will have to cut and extend a couple of plugs to make them reach but it will all work. Use a 96-98 gsr ecu or convert your car to obd-1 with a conversion harness and use a chipped p28. The only other issue will be the distributor. What year is the dizzy?
Old Feb 26, 2005 | 04:23 PM
VTECVillain's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">id persoanlly grab a 99 civic si or civic ex harness sicne it will match the ecu.</TD></TR></TABLE>
Well you would personally have a wiring situation on your hands going that route considering the car is a 96 (OBD2A) and the 99 Si/EX harness is OBD2B which = no workie. As mentioned the best route to take is using a 96-98 EX harness or simply reusing the stock harness, rewiring the IACV and adding some wires, not that hard to do. But basically that's your 2 options, any other harnesses will be a lot more work and a lot of rewiring, don't do it!
And by the way, the 99 B18C ECU will plug into the OBD2A harness because it is OBD2A. Integra's didn't change to OBD2B until 00.
Old Feb 26, 2005 | 05:04 PM
v4lu3s's Avatar
RTFM
learn something new everyday, i had thought that the changeover to obd2b was 99 for tegs and civics.
Old Feb 26, 2005 | 10:02 PM
is that true? its a 99 teg motor, could it still be obd2a? im gonna assure its obd2b unless yall can enlighten me.
but i think 00's did change from the 99's. like the imobilizers.
Old Feb 27, 2005 | 05:55 AM
Default Re: (BoostJockey)
1999 Integra's are OBD2A for sure, do some research and if you find the correct info you will see that they changed to OBD2B in 00.
Old Feb 27, 2005 | 07:08 AM
Turbogixxer's Avatar
Default Re: (VTECVillain)
VTECVillain is correct.
99 civic = OBD2b
99 integra = OBD2a
Like others said, you need a 96-98 civic harness. Different trims of civics had diffferent style sensor (most of the time). The EX harness will need less wiring work to work on the B18c.
Just beware, Some companys that sell swaps switch up ECUs, may sure it is off of a 96-99 integra or a JDM ECU (OBD2).
Old Feb 27, 2005 | 08:47 AM
didnt know that.. i was thinking obd2b.. well its a 96 ex coupe, so i could use the stock harness but its pretty hacked up from running ZCs. so if anyone sees this ands got one for sale..
Old Feb 27, 2005 | 02:29 PM
Evil-EK's Avatar
hilltopsalvage@hotmail.com
Email them, tell them what you need and tell them you were refered to them from Honda-tech.
Old Feb 27, 2005 | 05:57 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (Harness Help) sick of people not knowing what their talking about (BigBlockH22atch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch &raquo;</TD></TR><TR><TD CLASS="quote">You use a 96-98 ex harness. You will have to cut and extend a couple of plugs to make them reach but it will all work. Use a 96-98 gsr ecu or convert your car to obd-1 with a conversion harness and use a chipped p28. The only other issue will be the distributor. What year is the dizzy?</TD></TR></TABLE>Since when did OBD II cars (besides Integras) have engine harnesses?...That's a new one for me.. They have vehicle harnesses....by the way!!!
Old Feb 27, 2005 | 07:02 PM
Default Re: (Harness Help) sick of people not knowing what their talking about (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">Since when did OBD II cars (besides Integras) have engine harnesses?...That's a new one for me.. They have vehicle harnesses....by the way!!!</TD></TR></TABLE>
Engine harness, vehicle harness, a bunch of wires whatever you want to call it... thanks for your useless post. Funny thing is I don't see anywhere that turbogixxer referred to the harness as an "engine" harness. Even if he did 99.9% of people would also refer to it the same.
Old Mar 11, 2005 | 10:00 PM
so the one piece is called an vehicle harenss
and the 2 piece is and engine harness
than it is an engine harness
BuMp cause i want an answed and my threads go nowhere faster than bricks under my car!
Old Mar 12, 2005 | 04:55 PM
Evil-EK's Avatar
What the hell are you talking about. I was telling the guy what he needed to do to install his motor in his car. I didn't say a thing about vehicle or engine harnesses. You need to learn to read.
97accord_R
Mar 19, 2009 03:47 AM
SONIC BOOM
Feb 5, 2006 04:19 PM
blackie
Jul 17, 2005 01:31 AM
coreypoppej6
May 15, 2005 11:52 AM
who00knows
16
Sep 23, 2002 08:15 AM
