new here, got a delsol, wown't start
hey yall. just bought a sol. it's a 94 si. so the car wown't start. there's no spark to the plug wires or at the output of the distributor, i bought a used one from a running engine, and the same thing. engine just keeps trying to crank.
i tested the connector with 2 wires on it to the distributor, i get 12 at the fat one (black/yellow i think). but the connector with multi wires, no power to any of the wires. is this a prob?
all fuses are tested good.
so how to i check if the coil in the distributor is any good? or what should i do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillBot »</TD></TR><TR><TD CLASS="quote">Bad ignitor? My service manual is in NC...sowwy.</TD></TR></TABLE>
I would check into the ignitor ive had that go bad on me before with similar symptoms
hey, cool. i'll just take both distributors to autozone and have them tested. i turned the ignition to on today, the CEL does not come on, u know how it's supposed to come on for a few seconds and go off. i've seen other civic's do that. donno if maybe my ecu is bad or something
i had the same stupid *** problem. try your distributer on another car if it starts take the computer out that one and try that in your car. I bought a whole distributer before i found that out. let me know
hummm...i just peaked down where the ecu is, and wala, no it's there. but i see tape on alot of the wires. i'm gonna take it all apart and trypulling a dist and ecu from a running car, and see if all the wires are connected right.
jus ran into the same prob wit my 93 sol, i put a 98 D16 in my sol an couldnt get it started, same problems, check the ground wire running with the dist. after that then check the main relay under the dash in the fuse box, what i ended up doing was replacing all the main relays an fuses an tried starting it an it would start an i punched the fuse bo after alot of fustrtion an tried starting it again it fired right up.
hey, is the main relay the one(2 finger sized rectangular) that goes on teh inside fuse box or is it a big palm sized square one? i went to teh dealer with the small one from the dealer, they say it's nto the main relay, they said it's a big one that goes under teh steering column?
Jammersplace
17
Jan 29, 2006 04:11 PM
SenekaGSR
Dec 29, 2003 02:41 PM
