b16a swap in a 95 civic ex questions????
Old Feb 25, 2005 | 05:47 PM
BOOSTEDgreeneg's Avatar
Default b16a swap in a 95 civic ex questions????
I have a few questions about a b16a into my 95 civic ex. I bought a b16a long block and i was wondering what axles im going to need? I am going to be using a b16 or gsr tranny most likley a gsr one. I have a intermediate shaft from a 91 ls integra motor and was told i would need 90-93 intagra axles. Is that right? Also what linkage and motor mounts would i need? Thanks.
Modified by turbocivic13 at 3:08 AM 2/26/2005
Old Feb 25, 2005 | 06:02 PM
00000xxx's Avatar
Default Re: b16a swap in a 95 civic ex questions???? (turbocivic13)
you may need a gsr rear bracket all depending on if its a obd2 B16A or obd1, b-series axles, b-series shift linkage, if you have a 91 ls intermediate shaft you have to get 90-93 axles or at least 90-93 driver side axle,pretty sure you can use your 95 ex mounts they should both have a 2 bolt driver side mount, i would personally use a b16 tranny because of the gearing but thats all up to you, OH yeah if you have a jdm wire harness you need to pull the wire harness off your sohc motor and prolly do a little bit of wiring.
Modified by ctr610 at 10:13 PM 2/25/2005
Old Feb 25, 2005 | 06:14 PM
Default Re: b16a swap in a 95 civic ex questions???? (ctr610)
The motor is a obd1.
Old Feb 26, 2005 | 07:09 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivic13 &raquo;</TD></TR><TR><TD CLASS="quote">I have a intermediate shaft from a 91 ls integra motor and was told i would need 90-93 intagra axles. Is that right?</TD></TR></TABLE>
Yes, you will need a 90-93 Integra driver's side axle and a 90-01 Integra passenger side axle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivic13 &raquo;</TD></TR><TR><TD CLASS="quote">Also what linkage and motor mounts would i need?</TD></TR></TABLE>
You'll need a 94-01 Integra shift linkage and same goes for the mounts.
mgreen6393
Feb 12, 2012 04:18 AM
max_man4945
Sep 19, 2010 08:02 PM
matt8885
Dec 16, 2006 05:25 PM
90HFCrX
Jul 16, 2004 12:19 PM
B16BDOHCVtec
Dec 25, 2002 03:35 PM
