Vents..
Old Feb 25, 2005 | 04:41 PM
sleepin91teg's Avatar
Default Vents..
Got a question, my 89 civic si, has a lil problem...when i turn the heat/air on to any setting, it only comes out of the dash panel vents...anyone know WTF to do?
Old Feb 25, 2005 | 04:46 PM
CRX_1.8T's Avatar
Default Re: Vents.. (sleepin91teg)
You may need to crawl under yor dash to double check that all of the cables and stuff are still intact. There was a disconnected cable once on our Jeep and it did the same thing, the air flow was restricted to the dash vents. Just a thought, maybe try that if you havn't already.
Old Feb 25, 2005 | 04:52 PM
Default Re: Vents.. (CRX_1.8T)
Ill give it a shot sunday night...any other thougths?
Old Feb 25, 2005 | 04:57 PM
CRX_1.8T's Avatar
When you are checking under the dash, check out where the levers that attach the cables to the unit itself. That was where it broke on the Jeep, so what happened was basically the little lever was no longer pulling on a cable.
Old Feb 25, 2005 | 04:59 PM
Ok, makes sense but i also hear the door moving when i push the lever around
Old Feb 25, 2005 | 05:00 PM
CRX_1.8T's Avatar
Hmmmm. Do you remember what happened when it actually failed on you? Was there any sound of broken plastic or anything?
Old Feb 25, 2005 | 05:02 PM
hmm not really...
Old Mar 1, 2005 | 07:45 AM
just checked to see if the cable is still connected, and it is...so what now? mode doors arent opening obviously...prolly gonna have to tear the dash apart...right?
Old Mar 1, 2005 | 09:35 AM
CRX_1.8T's Avatar
Unfortunately it sounds like you may have to. So when you moved the lever, could you see them moving behind the climate control unit as well?
Old Mar 1, 2005 | 09:46 AM
lilneep16v's Avatar
my crx does the same thing, if ya find the problem let everyone know what it was.
the only time i ever remember to fix it is when i need defrost and cant see
Old Mar 1, 2005 | 10:53 AM
Default Re: Vents.. (lilneep16v)
Yes i moved the climate control unit out from the mounting bracket...i could see behind it and the lever is pulling and pushing the cable...my next question is if the mode doors are vacuum operated, cable, or electric?
Old Mar 1, 2005 | 10:55 AM
DieMaster's Avatar
Needs to be About 20% Cooler
cable
Old Mar 1, 2005 | 12:15 PM
allmotrjdm's Avatar
Default Re: Vents.. (DieMaster)
bump for josh! get his vents working
Old Mar 1, 2005 | 02:57 PM
progress's Avatar
Bump as I'm in the same boat. I've posted twice about this with no replies. If someone has a solution, please post! Thanks!
Old Mar 2, 2005 | 11:04 AM
Default Re: (progress)
Got this far...i talked to my HVAC teacher, and he told me its cable controlled, so i pulled some **** apart and noticed that the cable was still connected to the back of the hvac panel so then the cable should then go from there up in the dash some where to the mode doors, and it prolly broke off up there is his guess, easy fix, but time taking and alot to do...Hopefully i get it done, sux like this...any more info needed! Bump
Old Mar 2, 2005 | 11:06 AM
The thing that gets me the most on this...is i just had ac class, and i learned when the doors fail, they are designed so that to mode doors fall back to the defrost position, so no matter what atleast you can see...but this isnt the case...BUMMER
Old Mar 3, 2005 | 04:48 AM
Bump...also this may be easier if someone has an online helms manual for an 89 civic si....its in adobe acrobat reader format, i have one for my integra, but dont remember who or how i got it...
Old Mar 14, 2005 | 06:58 AM
Still nothing...
Old Mar 14, 2005 | 06:29 PM
bagpipe goatee's Avatar
you can get to where the cable attaches to the box without pulling the dash. look under the dash behind the center console, you should see all this linkage and gears and stuff. good luck.
Old Mar 14, 2005 | 08:37 PM
Default Re: (bagpipe goatee)
Does anyone know for sure, if the mode doors are vacuum operated or cable?
305_DB7ish
Mar 25, 2015 12:52 AM
sheepey
Mar 2, 2012 02:29 AM
navin
Dec 16, 2007 10:04 PM
CereaLand
Jun 16, 2003 06:37 PM
GRAVEDIGGER
Nov 16, 2002 01:25 PM
